Old Oct 09, 2014, 12:06 PM
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
FWIW, according to eCalc for the a60-7xs (v2) 320kV motor with Xoar PJN E props on a 8s 4500 25c/35c pack....
19x12 Optimum efficiency
2072W, 77.7A, 26.6V, 7791 rpm, 88.9%
19x12 Motor at maximum
2864W, 113.2A, 25.31V, 7155 rpm, 85.4%
20x10 Optimum efficiency
2072W, 77.7A, 26.6V, 7790 rpm, 88.9%
20x10 Motor at maximum
2896W, 114.7A, 25.25V, 7127 rpm, 85.2%
So, ignoring the maximums (which both are over the limit for the moto)r, at optimum efficiency 20x10 is virtually the same as a 19x12
The current predictions are pretty close to the Hacker recommended
http://www.hacker-motor-shop.com/e-v...&c=7013&p=7013
recommended Prop APC-E 19x10 (81A) at 8S Lipo
ltc is offline Find More Posts by ltc
Old Oct 09, 2014, 12:33 PM
United Kingdom, England, Hants
Joined Aug 2014
Mejzlik don't make a 19x12 E prop as I have found to my cost. Got a nice shiny prop here....for an IC engine! They do however make two 20x10, one being an extra light at less then 36g, hence the question. Figures you've posted look good so I may take a punt.
UKMouldy is offline Find More Posts by UKMouldy
Old Oct 09, 2014, 12:56 PM
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
Falcon makes a 19x12 electric CF prop... Mike at F3AUnlimited has them in stock
http://www.f3aunlimited.com/falcon-1...v2-carbon-prop
http://www.justmodelprops.com/produc...rbon-electric/
And i'm pretty sure APC makes a thin E prop 19x12 as well
Old Oct 09, 2014, 01:07 PM
Joined Aug 2014
Yup, APC definatly make one but I wanna go carbon. Quite a lot of flex in the APC E props, I have a 16x10 APC E on the Katana.
I also know about the Falcon prop but only one place here in the UK do them and they are pretty expensive. I was under the impression that Mejzlik were the benchmark in carbon props and I can get a 20x10 EL for less then then a Falcon 19x10.
However if the 20x10 doesn't work then its an expansive experiment. I guess the only way to really know is to get a Falcon and a Mejzlik.............
Old Oct 09, 2014, 01:59 PM
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
Perhaps just for the purposes of determining power levels you could use a (less expensive) Xoar PJN or PJH (F3A) electric wooden prop (or the APC-E) then buy the appropriate CF prop?
Old Oct 09, 2014, 04:16 PM
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
I stopped using e-props years ago, now I use regular ones in all brands, including Mejzlik (as there are far more size options), never had any issues...
Jack
jfetter is offline Find More Posts by jfetter
Old Oct 10, 2014, 07:54 AM
Dansy's Avatar
Joined Apr 2013
The non e-prop are just a little heavier due to the beefed up hubs I use them if theres no e- available for the size I want.....
Dansy is offline Find More Posts by Dansy
Old Oct 10, 2014, 08:58 AM
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
The issue I have with using non E props is that they require that I cut my spinners...something I try to not do unless absolutely necessary.
Old Oct 10, 2014, 01:36 PM
Joined Jun 2014
I just purchased a 16x10 xoar prop for my nuance and it has a thicker hub as well. I ended up using a thinner prop washer to get enough threads into the nut. I also had to trim out and rebalance that plastic e- spinner I got from f3au. Nice prop though. Nice look and quiet in the air.
WR_Rider is online now Find More Posts by WR_Rider
Old Oct 10, 2014, 04:19 PM
Joined Aug 2014
Interesting input. May well bolt the prop I have onto the 7XS then, hub is drilled for a 10mm shaft and the 7XS is of course 8mm. Easily sorted though!
Old Oct 11, 2014, 07:21 AM
Dansy's Avatar
Joined Apr 2013
I made some bushing for those occasion
Old Oct 11, 2014, 04:15 PM
Joined Aug 2014
like I said, easily sorted!
Build Log SebArt Sukhoi 29S 140E Build Thread... jfetter 3D Flying 438 Mar 31, 2014 11:31 PM
Mini-Review New Sebart KatanaS 30e - Build Thread/Mini-Review Bill K. 3D Flying 1067 Mar 11, 2014 12:03 AM
Build Log Turnigy (TECHone) Mythos Build Thread The_Mongrel Australia 13 Feb 13, 2013 07:59 PM
For Sale NEW SebArt Mytho S 125E FREE SHIPPING DiscountLipos Aircraft - Electric - Airplanes (FS/W) 9 Aug 29, 2012 05:00 PM
Mini-Review New SebArt KatanaS 50E - Build Thread/Mini Review Bill K. Sport Planes 334 Oct 04, 2010 03:44 AM
