Old Jun 16, 2014, 04:11 AM
Joined Dec 2012
New Product
RJX Vector 700 coming July 4 2014
Rjx vector 700 (2 min 3 sec)
IMG 5891 (1 min 58 sec)
Vector FF in thailand (2 min 12 sec)
http://helidaily.com/rjx-hobby-vector-700-coming-soon/
Another heli I have to get...
TheKingPhisher is offline Find More Posts by TheKingPhisher
Reply With Quote  (Disabled)
Old Jun 16, 2014, 11:06 PM
Atomic Skull's Avatar
Joined Dec 2011
Not crazy about the full fuse or the landing gear, I'd prefer skids and a canopy.
I'm building an RJX X-Treme 600 right now and the quality is at least as good as Align, probably better. One thing I like about it is that RJX uses oversized bearings on everything, the front tail drive bearings are as big as the mainshaft bearings (6x19x6 vs 10x19x6)
The only problem with RJX helicopters is that getting parts for them in the US is a pain in the butt. If you live in Europe you're set but RJX seems to have been cursed when it comes to finding a good US distributor.
Atomic Skull is online now Find More Posts by Atomic Skull
Old Jun 17, 2014, 05:29 AM
Joined Dec 2012
I absolutely love the full fuselage on the Vector...not only does it look cool but the shape is also unique...actually looks like a shark from head to tail. The airframe looks like a unique design too. I wonder why they went with the longer main pulley belt though. Anyway I like the anti-rotation link as well as the head design. The precut cooling vents for the ESC is sweet. Definitely going to get one of these before I get a Mostro and a Goblin Speed.
Old Jun 17, 2014, 02:13 PM
Joined Dec 2011
Because the belt belt drives an intermediate pulley which directly drives the tail belt pulley and the pinion on the main gear.
12S is more efficient but you have to use a motor with less efficient windings (thinner wire, more turns) High KV motors are more efficient (thicker wire, fewer turns) but you have to use 6S which is less efficient. This setup is the best of both worlds.
Most commercial motors use turns with multiple strands because they are easier to manufacture (it's harder to wind a motor with thick copper wire) which is a bit less efficient than a motor that uses single wire turns.
Here's a 600MX rewound with single strand turns (not my motor)
Old Jun 17, 2014, 06:59 PM
I win again!! - mother gravity
Flying Pitcher's Avatar
Greenland, Qaasuitsup
Joined Apr 2013
...Definitely going to get one of these before I get a Mostro and a Goblin Speed.
is it going to be also after you get that jr 700 you wanted too?
This just moved to the top of my to buy list and from JR too!
Flying Pitcher is offline Find More Posts by Flying Pitcher
Old Jun 18, 2014, 01:58 AM
Joined Dec 2012
It's right below the JR which I have preordered.
Old Jun 20, 2014, 10:40 PM
Joined Dec 2012
Yeah but my question is more about why they went with that type of design vs something like the Goblin and Mostro? Is there any advantage to that specific implementation or are they doing it just to be different?
Old Jun 21, 2014, 09:26 PM
Joined Jun 2014
whynotjused is offline Find More Posts by whynotjused
Old Jun 21, 2014, 10:30 PM
Joined Dec 2012
Stop being a Jackass....everyone knows who you are...
Too chicken to use your old account?
Old Jun 22, 2014, 04:52 PM
P.I.Engineer's Avatar
United States, CA, Redondo Beach
Joined Mar 2005
i like the a/r linkage design, haven't seen that before, it makes sense.
P.I.Engineer is offline Find More Posts by P.I.Engineer
Old Jun 22, 2014, 09:17 PM
Joined Dec 2012
Yeah it looks pretty interesting. So far there are about 4 different AR design types out there.
1. The traditional pin in elongated vertical slot
2. The triangular "A Arm" bracket used in Thunder Tiger and JR helis
3. The slightly different captured elevator servo link in horizontal slot used in the Compass Warp
4. The cantilever design in the RJX Vector
There may be others but those are the ones I've seen so far.
That said I'm still questioning why they went with a long main belt but are not using a "reduction gear"? If you look at the intermediate gear notice the small intermediate "pinion" that meshes with the main gear. It looks to be the same size as the motor "pinion"...which means it's not doing any additional gear reduction?
Old Jun 23, 2014, 06:01 PM
Joined Dec 2011
The motor pulley drives the secondary pulley which is larger, so the pinion spins at the same speed as the larger pulley not the motor. Also an S3M belt has larger teeth than a module 1 gear so the tooth counts are going to be different for the same diameter.
Old Jun 23, 2014, 08:15 PM
Joined Dec 2012
Ah ok I understand now...thanks for the explanation.
Old Jun 23, 2014, 10:15 PM
Joined Dec 2011
The maingear looks the same as on my X-Treme 600 btw which would make it a 100T 14mm thick CNC slant gear. If it's like other RJX helicopters they will have used M4 bolts that thread into tapped holes in the mainshaft on each side of the hub instead of jesus bolts.
Old Jun 25, 2014, 04:57 PM
Joined Mar 2005
i hate the captured slot style a/r design. It relies too much on things being very well aligned.
Sold 2 sets @ RJX 325mm green vector blades ptflyer Aircraft - Electric - Helis (FS/W) 3 May 15, 2014 01:44 PM
For Sale Brand New AR7200BX, RJX flybarless head for a 600 heli Resparky Aircraft - Electric - Helis (FS/W) 0 Oct 01, 2013 12:33 AM
Sold RJX Trex 700 or Raptor 60/90 Flybarless Head " New " alfajet Aircraft - Fuel - Helis (FS/W) 2 Oct 18, 2012 09:21 PM
Discussion New 700 Size from RJX Hobby guyro Electric Heli Talk 0 Mar 04, 2012 08:03 AM
Sold RJX 90/700 size fbl head e-heliflyer Aircraft - Electric - Helis (FS/W) 3 Sep 11, 2011 12:29 AM
