Old Oct 19, 2013, 05:05 AM
A man with too many toys
United States
Joined Feb 2001
What’s new?
Any new products coming out before next spring?
RC Man is offline Find More Posts by RC Man
Old Oct 22, 2013, 03:40 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
None that I have planned. What are you looking for?
The Don is offline Find More Posts by The Don
Old Oct 22, 2013, 06:34 PM
United States
Joined Feb 2001
I have a 4000 plus 64mm setup in my stinger. When I installed it I thought that it would have a little better performance with some streamlining to reduce drag. A fearing between the motor and fan to fill that large space would help. An airfoil shape to cover the wires would reduce drag even more. Those wires are in the highest energy part of the air stream.
You could make some plastic parts to do the job. I expect that they would sell very well. What do you think?
Old Oct 22, 2013, 06:45 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
The drag is in the airframe. Did you install the thrust tube? You should be 100-105 mph with the setup you have in the Stinger. Put that same setup in a HP F16 and it will be ~115 mph as it is a cleaner airframe.
Old Oct 29, 2013, 10:43 PM
Registered RC NUT!
The Snake's Avatar
United States, CA, Lomita
Joined Jun 2002
Setup D: For 4S lipo (about 830 watts) For 4S lipo, max power I sell in 64mm.
You have not stocking the HET fan units anymore Don? Your EDO Type I EDF with a 4400 plus EDF is close to the same watts?
The Snake is offline Find More Posts by The Snake
Old Oct 29, 2013, 10:51 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I do not have any 6404s in stock and they are not a popular selling fan so I have not reordered. I can mount a motor to one if you send me a fan. The EDO Type 1 is not really rated for those high watts, it will probably blow off the blades.
Old Oct 29, 2013, 11:00 PM
Registered RC NUT!
The Snake's Avatar
Joined Jun 2002
If I may ask Don, have you tired any other 64MM fan units and/or considered stocking higher blade count fan units?
Discussion What's inside the NEW Dynam A-10 Thunderbolt II Jet? hobbypartz Nitro Planes 0 Jun 26, 2013 02:08 PM
Discussion What's Your 'New' Heli Checklist? Falafel Flop Beginner Training Area (Heli-Electric) 10 Jun 13, 2013 05:34 PM
Question I can't stay away....so what's new out there? Need some recommendations... Sky_Dancer Mini Helis 10 Jun 11, 2013 05:03 PM
Discussion What's new for you in 2013? Panther F RC Tanks 8 Apr 10, 2013 05:36 PM
Discussion What's "NEW" PCaola Micro Helis 0 Feb 08, 2013 08:17 PM
