This thread is privately moderated by Pilot_Tony, who may elect to delete unwanted replies.
Old Dec 12, 2011, 07:11 AM
Crash Test Dummy
Pilot_Tony's Avatar
Youngstown, PA 15696
Joined May 2002
Trader Rating: 109
For Sale
Sennheiser HMEC-25-CAP ANR Pilot Headset
1 slightly used headset in great condition. Asking $400 or best offer plus shipping, sell new for $680. Please PM with any questions.
Factory specs:
* Very lightweight -less than 7 ounces (190 grams)!
* Two-piece adjustable headband ensures excellent comfort
* Robust
* Excellent transmission of speech due to noise-compensated condenser microphone
* Flexible mic boom, can be worn on either left or right-hand side
* Single-sided cable
* 15 dB active noise cancellation
* 16 dB passive noise reduction
* FAA and JAA TSO approval C 57a and C 58a.
Technical Data - Headphone:
Transducer Principle: Dynamic, open.
Ear Coupling: Supra-aural.
Frequency Response: 30 - 16,000 Hz.
Nominal Impedance: 600 ohms (2 x 1200 ohms in parallel).
Characteristic SPL at 1kHz, imW: 100 dB +/- 2 dB
THD: < 1 %
Load Rating: 200 mW.
Contact Pressure: Approx. 3.3 N
Weight (without cable): Approx. 140 g
Technical Data - Microphone Inclusive of Preamplifier:
Transducer principle: Back Electret Noise-Compensated Condenser Microphone Capsule.
Frequency Response at a Distance of 2 cm From Swivel-Mounted MIC Boom: 200 - 8,000 Hz 8
Max. SPL: 120 dB (THD = 1%).
Output Voltage: 170 mV +/- 6 dB at 114 dB and a distance of 6 mm.
Terminating Impedance: 470 ohms.
Connections:
Connection Cable: 1.8 m, Single-Sided Flat Cable.
Headphone Connector: 5-pin XLR connector
Microphone Connector : Microphone PJ-068 (5.25 mm ).
As HMEC 25-CAP NoiseGard circuit powered via 28VDC from the aircraft via pin-5 of the XLR
connector. 1.8m cable with 5-pin XLR connector.
Headphone Frequency response: 16-22,000Hz, Impedance: 200 Ohms mono
Microphone Frequency response: 300-5,000Hz, Impedance: 150 Ohms
JAA Approved - Part No. 025-230-325
Thanks for looking,
Tony
Pilot_Tony is offline Find More Posts by Pilot_Tony
Sold hanger 9 25%cap 232 daleandhelen Aircraft - Fuel - Airplanes (FS/W) 0 Dec 08, 2011 07:11 PM
For Sale Sennheiser HMEC-25-CAP ANR Pilot Headset Pilot_Tony Non R/C Items (FS/W) 1 Dec 07, 2011 10:25 PM
For Sale Sennheiser HMEC-25-CAP ANR Pilot Headset Pilot_Tony Non R/C Items (FS/W) 0 Oct 21, 2010 07:01 PM
For Sale Sennheiser HMEC-25-CAP ANR Pilot Headset Pilot_Tony Non R/C Items (FS/W) 2 Oct 07, 2010 10:56 AM
Gallery Baseball-cap-mounted Eyetops headset Hogster Aerial Photography 8 May 07, 2007 01:15 PM
