Old Mar 23, 2010, 05:44 AM
Per Ardua Ad Astra
Berkie's Avatar
Australia, VIC, Rosebud
Joined Feb 2007
Looking for a Cellpro 10S connector
Does anyone know if any of the various HobbyKing balance connectors that they have will work with Turnigy LiPos and the Cellpro 10S?
Kev
Berkie is offline Find More Posts by Berkie
Old Mar 23, 2010, 06:15 AM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
The only other LiPoly balancing connector that uses the same size pins and spacing as the FMA ones are the Tunder Power ones. The Thunder Power housings are a bit larger and the keys and latches are different but can be trimed to fit. I have used many TP ones with my Cell 10.
Old Mar 23, 2010, 08:04 PM
Per Ardua Ad Astra
Berkie's Avatar
Joined Feb 2007
Thanks.
Would this be one?
MKS 3 in 1 Batt-Balancer Adaptor for Thunderpower 2S-6S
http://www.hobbycity.com/hobbycity/s...idProduct=8689
Old Mar 23, 2010, 08:46 PM
Southern Pride
I have no idea what that cable fits,perhaps a HK charger but it is 7 leads and the Cell Pro 10 takes a 6lead same spacing and connectors as TO 5S 6 lead which as I stated can be trimed to fit the CP10.
Photo of a modified TP6 lead to fit CP10
http://www.rcgroups.com/forums/attac...8&d=1220786344
Connected to CP10
http://www.rcgroups.com/forums/attac...1&d=1205453764
Old Mar 23, 2010, 11:18 PM
Hemet, California, United States
Joined Aug 2001
Hi,
I charge Hobby King Turnigy lipos on my 10S using adapters sold by FMA Direct. About $20.00 shipped. Want it fast with no hassle? Get it from FMA Direct.
Good luck! Mickydee
mickydee is offline Find More Posts by mickydee
Old Mar 24, 2010, 12:18 AM
Novice RC pilot
u.rusty's Avatar
California
Joined Feb 2008
Here is a link to the Cellpro adapters:
http://www.fmadirect.com/cellpro_adapters.html
Turnigy LiPo batteries apparently use JST-HX balance connectors
According to the FMAdirect adapter information, you need one of the following adapters:
Single channel:
http://www.fmadirect.com/detail.htm?...271&section=45
Dual channel:
http://www.fmadirect.com/detail.htm?...279&section=72
Note: I only plug one balance channel in at a time with the dual channel adapter. It has two adapter choices on it. In any case, be sure to read the manual for correct use.
u.rusty is offline Find More Posts by u.rusty
Old Mar 24, 2010, 06:46 AM
Per Ardua Ad Astra
Berkie's Avatar
Joined Feb 2007
Thanks everyone!
Yes I know about the genuine adaptors. I have one but was thinkig of getting another to charge 2 packs at once. Out here though they cost about US$33 posted & when I saw similar adaptors at HK for about $7 I thought I would ask.
I think though, with my limited knowledge it will be safer to go for another FMA
Cheers
Kev
Discussion cellpro 10s and field battery xatled99 FMA Direct 4 Mar 21, 2010 10:28 AM
Discussion CellPro 10s question jhaywood Batteries and Chargers 2 Mar 12, 2010 02:58 PM
Wanted WANTED a FMA CELLPRO 10S USB Interface Module for 2 way data communication mechengineer03 Aircraft - Electric - Batteries & Chargers (FS/W) 6 Sep 06, 2009 11:52 PM
Wanted Looking for Cellpro 10s charger triguis Aircraft - Electric - Batteries & Chargers (FS/W) 1 Dec 06, 2008 03:24 PM
Discussion Cellpro 4s or Cellpro 10s for charging multiple packs?? windisevil!! Batteries and Chargers 16 Mar 25, 2008 02:57 PM
