Old Feb 09, 2013, 10:05 PM
marshall s is offline
Find More Posts by marshall s
Joined Dec 2012
servo size
what size of servo does a rock crawler need?
marshall s is offline Find More Posts by marshall s
Old Feb 13, 2013, 08:19 AM
hoghead5150 is offline
Find More Posts by hoghead5150
The wind caused that!!
hoghead5150's Avatar
United States, OK, Poteau
Joined Jul 2012
depends on what scale your crawler is. basically most use a standard sized servo. now if your going to be powering the servo with the internal bec inside your esc it's not gonna make a whole lot of difference what servo you put on there. any servo that will do you any good crawling will draw more power than the wimpy internal bec's can provide.
if you add an external bec (like a castle creations 10amp), then you can take advantage of powerful servos. i prefer the hitec 7950, you should shoot for at least 300oz of torque, and the closer you get to 400oz the better off you'll be.
keep in mind that getting a good servo will also lead to more modifications. most stock crawlers have plastic flimsy steering links. these won't hold up and will have to be changed. also plastic c-hubs and knuckles already have a hard time staying together with stock steering, so when you add more power you will have to replace those also.
hoghead5150 is offline Find More Posts by hoghead5150
Sold Complete electronics setup for 400 size Helicopter, Servos Motor Esc and Gyro dunwrkn Aircraft - Electric - Helis (FS/W) 1 Feb 10, 2013 11:41 PM
Discussion Digital" VS "Analog" servos 60 size fun fly plane eng30 Radios 2 Jan 27, 2013 03:30 PM
Discussion small servo sizes Taz H Radios 5 Jan 21, 2013 08:46 PM
Discussion Confused - prop size vs motor size vs thrust cloud_9 Power Systems 26 Jan 14, 2013 03:05 AM
What size servos for a fixed pitch .30(?) size heli? GregG Fuel Heli Talk 0 Dec 28, 2002 04:33 AM
