Old Mar 29, 2008, 01:33 AM
jcm1010's Avatar
Milwaukee
Joined Apr 2003
Charging A123 cells with astro 109 upgraded with a123 chip
I just upgraded my astro 109 charger with the A123 Ver 1.2 chip. When I plug the pack in it reads as a 6 cell pack and charges to 21.6v. Only problems that it is a 7 cell pack. I switch the chip back to the old 109 chip and it still read as a 6 cell pack but charges to 25.2. Has anyone else had a problem charging 7 cell A123 packs with the upgrade chip.
jcm1010 is offline Find More Posts by jcm1010
Old Mar 29, 2008, 11:26 AM
lutach's Avatar
New Jersey
Joined May 2004
I charge my 10S packs with my 109 and it charges them as a 9S pack.
lutach is offline Find More Posts by lutach
Old Mar 29, 2008, 11:34 AM
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Can you check that the displayed voltage is correct, either with a multimeter or Wattmeter?
I have a V1.1 A123 charger and it gives the correct voltage and cell count, so something is not quite correct with yours.
But the A123 can't change cell count in phase 1, so often I have to reconnect it if the packs starts of completely discharged.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Mar 29, 2008, 02:33 PM
Fly Backwards
hcopter's Avatar
Pittsburg KS, USA
Joined Dec 2000
If I run my 5 cell packs down completely then my 109 (123 chip) will see it as a 4 cell. I just plug in the pack and turn the knob all the way up, it will charge for the first 30 seconds then say charge is complete, repeat that one or two more times and it will get the voltage high enough to see it as a 7 cell from the start then your good to go.
hcopter is offline Find More Posts by hcopter
Old Mar 29, 2008, 08:53 PM
USA, FL, Apopka
Joined Dec 2000
You are running your packs down to a voltage that is within the valid voltage range for both a 4 cell and a 5 cell pack. Remember an Astro 109 will at start up always choose the lowest valid cell count for the voltage range. Now with the A123 version Cycle 1 is only 30 seconds long so the voltage did not rise high enough to cause a cell count bump before it locked in the cell count a cycle 2.
So turn the amps knob full right (A123 M1's can take the amps) and if the cell count is low at C2, just unplug and start again.
I have never had to restart more then 1 times even with packs up to 8S..
Brad
bradpaul is offline Find More Posts by bradpaul
Reply With Quote  (Disabled)
Old Mar 30, 2008, 12:05 AM
Torrance
Joined Feb 2005
no problems with the 123 chip works great
JustinONE is offline Find More Posts by JustinONE
Old Jun 17, 2008, 02:26 PM
Oxford,Mississippi
HighNear90's Avatar
Oxford, MS U.S.A.
Joined Aug 2000
I installed the A123 chip in my 109 and it works great for my 7s packs......But will it charge my 10s pack? I plugged the pack in and it says "xc1"......is the "x" the roman numeral for "10" or is it saying "what the heck did you just plug into me".....Does anyone know?
THanks,
Leo
HighNear90 is offline Find More Posts by HighNear90
Old Jun 17, 2008, 02:59 PM
Dan Baldwin's Avatar
United States, CA, Norwalk
Joined Apr 2004
Yes, it is saying that you have a 10 cell pack, and it should charge fine. They only had one digit available to display the cell count, so they couldn't display "10".
Which version of the firmware do you have?
Dan
Dan Baldwin is offline Find More Posts by Dan Baldwin
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
I have a ASTRO Deluxe 12 --
in fiddlin around -I found it works just fine on A123 -5 cell etc., packs - just jot down the desired max voltage -when fully charged - then -turn knob to zero -then wind it to th full right -watching th voltage - IF--the pack is charged up -th voltage will climb quickly above desired voltage
IF it is lower than desired voltage - let it charge and once it gets a bit over desired voltage th nunbers will climb fast
shut it off. You wil lfind that th pack will likely be a but UNDER charged--
But I use a good VOM and read the cells after about 5 minutes and if charge is 3.5 aprox per cell - close enough
if reading is 3.7 v per cell -- still-- close enough-
If yo can't stand by and watch the charge -- do not try this - it will possible wreck the cells if it runs up into 5-6-7 volts per cell.
don' say you were not warned ---
spel chek borke
richard hanson is offline Find More Posts by richard hanson
Old Jun 17, 2008, 03:10 PM
Oxford,Mississippi
HighNear90's Avatar
Oxford, MS U.S.A.
Joined Aug 2000
Dan
THanks Dan, I'll check the firmware version when I get home. I don't know what I was thinking and bought the switch and resistors that pmack says in this thread: http://www.rcgroups.com/forums/showp...3&postcount=56
But I guess I don't need them.....Anyone need them? I bought 3 of each (switch and resistors).
--Leo
Old Jun 17, 2008, 08:44 PM
Oxford,Mississippi
HighNear90's Avatar
Oxford, MS U.S.A.
Joined Aug 2000
Dan
It's version 1.2 and I put the 10s pack on the charger and it charged them to 36v.......WoooooHoooooo.......I don't have to buy another charger......!!!!!......
--Leo
Old Jun 17, 2008, 09:02 PM
100% electric since 1990
twest's Avatar
United States, MA, Ware
Joined Jul 2001
Are you using a balancer? I just bought an 8 cell a123 pack, and on the first charge, one cell was so low that I had to charge the pack for 2 hours at 0.25 amps with the blinky in place. My pack was reading as a 7s pack because one cell was way under charged.
Since I balanced the pack, the has been charging/discharging normally, with the cells in reasonable balance. I don't think you need to use a balancer with each and every charge with a123, because they can tolorate over/under charging well, but you definately need to use one on the initial charge.
twest is online now Find More Posts by twest
Old Jun 17, 2008, 09:31 PM
Torrance
Joined Feb 2005
I have a spare a123 chip for new astroflight chargers, $10 plus paypal and shipping fees.
pm me or email is fri003@pacbell.net guaranteed not DOA
also have the a123 blinky $20
and one extrema blinky set up for 123's $30
Sold - SOLD! - Astro 109 Lipo Charger (Upgraded Chip Version 1.7) with Deans Connector rcGman Aircraft - Electric - Batteries & Chargers (FS/W) 3 Sep 26, 2007 08:15 PM
Discussion Astro 109...Max charging rate with 4 or 6 cells? wrenwright Batteries and Chargers 5 Apr 17, 2007 12:24 AM
Discussion Charging a 10s2p A123 Pack w/Astro 109 FlyingW Batteries and Chargers 5 Jan 19, 2007 03:41 PM
Alert Astro 109 version 1.7 chip upgrade staggerwing Batteries and Chargers 23 Sep 28, 2006 09:10 AM
Discussion Charging single LiPo cell with Astro 109 AndreyT Batteries and Chargers 3 Feb 21, 2006 11:36 PM
