Old Dec 02, 2014, 04:10 PM
Joined Nov 2010
prop shaft holder diameter
Hi Guys, I have a prop shaft similar to the one in this link: http://i59.tinypic.com/2enp7de.jpg
Mine takes a 1/4" flex cable at one end and an M5 thread at the other. I need to buy a prop shaft holder, I don't have an accurate tool for measuring the diameter but would I be correct in thinking the prop end of this shaft would be 5mm diameter? The holder would be sitting in between the thread and the part that holds the flex cable.
I was a bit concerned that a 5mm shaft holder might be way too tight for movement with a 5mm shaft? or is that the correct size? (I have to order it online so I cant take my shaft along to try it out first unfortunately.
flamer is offline Find More Posts by flamer
Old Dec 07, 2014, 12:22 AM
Joined Nov 2010
bump?
Old Dec 07, 2014, 01:21 AM
20M northeast of Hell Mi
liljimmy's Avatar
United States, MI, Howell
Joined Jul 2012
Try the speed boat threads http://www.rcgroups.com/racing-boats-electric-57/
They may need more information than what you have .post Photos of current setup/ under hull strut? Aft strut? I have no clue on "flex" shafts . I built with 4mm ss shafts.
liljimmy is offline Find More Posts by liljimmy
Discussion I need some long 3mm diameter motor shafts. RCvertt Dock Talk 4 Sep 25, 2014 09:32 PM
Discussion Coax outer main shaft that is 3 mm diameter? RCvertt Coaxial Helicopters 0 Sep 22, 2014 07:50 PM
Question APC type prop diameter vs Folding prop diameter hog2soar Electric Sailplanes 19 Nov 01, 2013 06:29 PM
Question APC type prop diameter VS Folding prop diameter hog2soar Sailplane Talk 5 Oct 29, 2013 05:19 PM
Help! 3.54mm diameter prop shaft? JeremyBB Dock Talk 11 Oct 16, 2013 09:22 PM
