Old Jun 07, 2012, 03:07 AM
Vancouver BC
Joined Sep 2007
spektrum dx7,AR6100 receiver
would a spektrum dx7 and AR6100 receiver work with brushed motor and its speed control? or that is two different families we are talking about? if any of that works, what are the combinations? thanks
Barelias is offline Find More Posts by Barelias
Old Jun 07, 2012, 07:12 AM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
Radio talks to receiver so DX7 and AR6100 = OK
brushed motor requires brushed esc = OK
If your esc has a Futaba style servo connector you may need to trim the excess plastic off in order to fit the port style of spektrum but they will talk to each other just fine.
freechip is offline Find More Posts by freechip
Old Jun 07, 2012, 08:38 AM
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Simply no issue. If the ESC connector fits the receiver, it will work.
Daedalus66 is online now Find More Posts by Daedalus66
Old Jun 07, 2012, 01:54 PM
Vancouver BC
Joined Sep 2007
also u mean spektrum dx7 with AR6100 works with brushed receiver and brushed ECS?
Old Jun 07, 2012, 01:55 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Yes, I have that combination in my old Pico Stick.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Jun 07, 2012, 02:07 PM
Vancouver BC
Joined Sep 2007
i didnot work with my glider with 600 size brushed motor. is there a specific setting with the AR6100 receiver? so its spektrum dx7 with AR6100 , 600brushed motor and its 25amp ESC and 2100 3cell lipo.
Old Jun 07, 2012, 02:45 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Why don't you list all your equipment, a photograph of the installation, and settings such as throttle trim? Many ESCs need throttle trim all the way down to arm properly.
We can't help you much without complete information.
Andy
Site Sponsor
Old Jun 07, 2012, 06:30 PM
Vancouver BC
Joined Sep 2007
the glider has only rudder and elevator, so the AR6100 receiver, has elevator servo hooked to elevator and rudder to rudder. the first goes for the little that used for binding, and throttle for throttle. so for throttle trim down, do you mean the in dx7 menu there is throttle trim high and low? so the low one should go down? and the high by how much. give me an idea so ill start some trial and error.
thanks
Old Jun 07, 2012, 06:53 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
What ESC are you using?
To set the throttle trim, you use the throttle trim on the front of the transmitter. You also need to have the travel setup on the throttle to 100% (at least) for most ESCs.
Try this:
Reset the model you have. Re-bind the transmitter and receiver. Make sure your servos all work. Now tell us what is happening in detail.
Andy
Site Sponsor
Old Jun 25, 2012, 02:50 AM
Vancouver BC
Joined Sep 2007
its working now
thanks
Old Jun 27, 2012, 04:38 AM
Vancouver BC
Joined Sep 2007
every thing is working now but the motor start only when i move the throttle stick half way!! i have high 100 and low 100!!how should i fix that ?
Sold Spektrum DX7s 2 included!! AR8000 and ar6100e with vemon hard case! Ori Paamoni Aircraft - General - Radio Equipment (FS/W) 7 May 10, 2012 11:25 PM
For Sale Spektrum DX7 TX with AR6100e RX and new 2500 ma Battery stafphoto Aircraft - General - Radio Equipment (FS/W) 3 Mar 21, 2012 09:57 PM
For Sale Spektrum DX7 heli transmitter w/AR6100e Receiver new condition!!!! w/original box! m1a2ab Aircraft - General - Radio Equipment (FS/W) 0 Mar 13, 2012 12:51 PM
Sold New Spektrum AR6100E receiver $18 shipped tlrascal Aircraft - General - Radio Equipment (FS/W) 6 Feb 25, 2012 09:15 AM
Sold Spektrum DX7 (heli version) + AR6100 + Spektrum neck strap + neck strap adapter generalbacardi Aircraft - General - Radio Equipment (FS/W) 4 Dec 15, 2008 07:42 PM
