Old Feb 09, 2012, 04:32 PM
1/2as actually fit in my car
United States, PA, West Grove
Joined Aug 2011
thinking about building r/c killer bee
i wanna build an r/c killer bee. now my question isnt how i should do it. but what would be a good plane to use it on. my build history is only 2 herr cubs. ive been flying for years but everything ive had was an arf our bought used. ive also thought about converting an electric like i did with a goldberg tiger 400. anyone have any thoughts. as long as its pretty easy to build i should be fine.
bushcub is offline Find More Posts by bushcub
Old Feb 10, 2012, 05:20 PM
Tiny diesels.... I love 'em
United Kingdom, England, London
Joined Aug 2011
A .049 stik would be a good simple build and great to fly!
nitroairplane is offline Find More Posts by nitroairplane
Old Feb 10, 2012, 08:15 PM
Joined Aug 2011
i have been wanting a stick for a while maybe ill go that way.
Old Feb 10, 2012, 08:37 PM
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
You can beat anything you want with a stick, but you can't beat a stick :-)
here is a nice low wing Joy Stick
ozmo01 is offline Find More Posts by ozmo01
Old Feb 12, 2012, 06:54 PM
Joined Aug 2011
anyone got any tips for bringing up my rpms? obviously i cant use a spi cylinder with the cox rc conversion. so i was gonna use a black widow cylinder with a killer bee crank and a mylar reed.
Old Feb 12, 2012, 11:53 PM
I'm going flying!
rcflyer-rick's Avatar
Colchester IL
Joined Oct 2009
I did a baby bee with an 8cc tank. Dual bypass, dual booster (one each side) stainless reed, lapped the crank to the case with toothpaste to polish the front of the crank-back of the case, sanded back of case with 600 grit wet to get a good gasket seal. Drilled out back venturi and cleaned up where the screen would be. rtv over the screwheads. On the 4th run with a 5.5x3 prop I was getting 18,400+ rpm but now it only runs about 1min15 seconds on 8cc's. So if your gonna hop it up be ready to install a larger external fuel tank.
rcflyer-rick is offline Find More Posts by rcflyer-rick
Old Feb 13, 2012, 01:57 AM
Joined Aug 2011
what kind of tooth paste? also while im looking i was thinking about a stick then i had an idea. i miss my dura plane and i have an extra wing from my first herr cub. so i think im gonna build an .049 dura plane look alike with light ply and my spare wing
Old Feb 14, 2012, 01:52 PM
Joined Aug 2011
i was thinking . what if i bore out the throttle too? more air means more power right. if it wouldnt make it so weak id bore out the whole choke tube the throttle mounts to also. there has to be a way to get a decently high rpm r/c conversion.
Old Feb 16, 2012, 01:04 PM
www.coxinternational.ca
xenalook's Avatar
Joined Mar 2008
There will be no advantage to boring out the throttle as the opening is already at least 4x the size (in area) of the engine's venturi hole.
By using this product, you will add another 1,000 RPM to your engine:
http://coxengines.ca/product.php?pro...&cat=27&page=1
Plus, use all the other mods you mentioned.
Bernie
xenalook is offline Find More Posts by xenalook
Old Feb 16, 2012, 11:14 PM
RknRusty's Avatar
United States, SC, Columbia
Joined May 2010
The #1 BW cylinder has SPI. Just get a Surestart cylinder without SPI. It's dual ported and fluted, a good performer.
RknRusty is offline Find More Posts by RknRusty
Old Feb 17, 2012, 11:37 AM
xenalook's Avatar
Joined Mar 2008
This cylinder is non-SPI:
This one has SPI:
Bernie
Old Feb 17, 2012, 11:53 AM
Western KY
Joined Sep 2003
Here's another option to consider from COX International:
http://coxengines.ca/product.php?pro...&cat=13&page=1
andrew
Andrew0820 is online now Find More Posts by Andrew0820
Old Feb 17, 2012, 01:12 PM
xenalook's Avatar
Joined Mar 2008
Unfortunately, that cylinder/piston setup will not work with our rear-mounted throttle.
The throttle works on the principle of airflow reduction, whereas SPI induces airflow increase; therefore negating the throttle's efforts.
Bernie
Old Feb 17, 2012, 02:15 PM
Western KY
Joined Sep 2003
Aaaaah! That's right --- he wanted a R/C Bee, not pure Killer Bee. Then, that would also rule out the second option in your earlier post?
Old Feb 17, 2012, 02:17 PM
xenalook's Avatar
Joined Mar 2008
Correct, that would rule out the 2nd. option. I just showed it for comparison purposes.
Bernie
Discussion Building a pond/pool for r/c boats shipcollector5 Scale Boats 24 Oct 09, 2011 12:50 AM
Yippee! Robs R/C Hobbies, Killer Online Prices wbrannies Hot Online Deals 0 Sep 08, 2011 11:00 AM
Discussion Building my First R/C baird123 Beginner Training Area (Aircraft-Electric) 3 Jul 15, 2011 09:07 PM
Off Site COX R/C BEE .049 NO. 360 and MEDALLION .049 NO. 240 on eBay ending Thr. Apr. 21, 2011 Richard N Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 19, 2011 09:11 AM
Help! Building an r/c plane from scratch piXel_neRd Electric Plane Talk 7 Mar 15, 2011 01:29 AM
