Closed Thread
This thread is privately moderated by S11D336B, who may elect to delete unwanted replies.
Old Dec 18, 2011, 10:39 PM
S11D336B's Avatar
USA, FL, Winter Springs
Joined Apr 2006
v3.1.515
Released new HoverflyPro and HoverflyGPS firmware. Also a new setup client is available for download here:
http://www.hoverflytech.com/Software_Updates.html
Fixes:
1. Firmed up yaw resonse to stick
2. Applied fix for GPS toilet bowl
3. Added option for Camera Gimbal Advance (forces the gimbal to move faster, must be configured in setup client)
4. Added option for Camera Gimbal Endpoints (Must be configured in setup client)
5. Added support for MediaTek GPS units
6. Fixed issue where camera mount parameters didn't load properly in the setup client
7. Added support for calibrating ESCs with the board (starting with throttle high turns the board into a y-splitter)
8. Camera mount now only starts when the board is armed
9. In the setup client, added option to enable/disable the camera mount (to prevent gimbal smash)
10. Home position is now set each time the craft is armed
11. Fixed twitching on GPS activate
12. Reduced return to home speed by 40%
13. Added ability to calibrate Turnigy ESCs with the board (Start board with throttle at full, board then acts like a Y Connector for all the ESCs)
14. Fixed flight logger
S11D336B is offline Find More Posts by S11D336B
Site Sponsor
Old Dec 22, 2011, 02:32 AM
S11D336B's Avatar
Joined Apr 2006
v3.1.523
Fixes:
1. Fixed issue with autoleveling drift
2. Further fixed issue with potential toilet bowl on GPS Hold
Site Sponsor
Old Jan 04, 2012, 04:19 PM
Hoverfly Technologies
hoverben's Avatar
United States, FL, Winter Springs
Joined Nov 2011
If you are using firmware update v3.1.523, we ask that you avoid flying with auto-level engaged, as you may experience some unpredictable results.
When paired with our recommended Turnigy (and similar) ESCs, the board may briefly command the ESC to go to 0 speed then command it to go higher. The ESC can not respond quickly enough to this and may cause an arm to drop suddenly.
hoverben is offline Find More Posts by hoverben
Old Jan 09, 2012, 08:04 PM
S11D336B's Avatar
Joined Apr 2006
v3.2.540
Warning:
Accelerometer MUST be recalibrated before flying this firmware
Fixes:
1. Fixed Camera Mount yaw issue (Bungee effect)
2. Fixed autoleveling yaw issue
3. Fixed issue which caused GPS hold to drift when yawing
4. Fixed issue which caused position hold drift if yawing before engaging position hold
5. Fixed issue where autoleveling can drop an arm when making vigerous corrections
6. Improved Magnetic heading hold
7. Improved ascent/descent characteristics
8. Re-tuned takeoff detection
9. Increased yaw correction ceiling
Site Sponsor
Old Jan 19, 2012, 06:49 PM
S11D336B's Avatar
Joined Apr 2006
v3.2.559
Fixes:
1. Fixed issue which caused some users to report twitching.
Site Sponsor
Old Feb 01, 2012, 10:37 PM
S11D336B's Avatar
Joined Apr 2006
v3.2.560
Fixes:
http://hoverflytech.zendesk.com/entr...elease-3-2-560
Site Sponsor
Old Feb 09, 2012, 08:31 PM
S11D336B's Avatar
Joined Apr 2006
v3.2.584
http://hoverflytech.zendesk.com/entr...elease-3-2-584
Site Sponsor
Old Feb 12, 2012, 01:06 AM
S11D336B's Avatar
Joined Apr 2006
Setup Client Update v1.5.0.36
http://hoverflytech.zendesk.com/entr...pdate-1-5-0-36
Site Sponsor
Old Feb 26, 2012, 10:42 PM
S11D336B's Avatar
Joined Apr 2006
v3.2.629
https://hoverflytech.zendesk.com/ent...lease-v3-2-629
Site Sponsor
Old Apr 06, 2012, 06:40 PM
S11D336B's Avatar
Joined Apr 2006
Firmware v4.0 is live!
https://hoverflytech.zendesk.com/ent...se-version-4-0
Site Sponsor
Old May 17, 2012, 03:15 AM
S11D336B's Avatar
Joined Apr 2006
Setup Client Update
https://hoverflytech.zendesk.com/ent...date-v1-5-0-46
Site Sponsor
Old Jul 09, 2012, 05:08 PM
S11D336B's Avatar
Joined Apr 2006
Firmware Release v4.3.800
Release Notes:
https://hoverflytech.zendesk.com/ent...lease-v4-3-800
Please READ!!!
Site Sponsor
Old Jul 26, 2012, 07:23 PM
S11D336B's Avatar
Joined Apr 2006
New HoverflyPro/GPS Firmware released.
https://hoverflytech.zendesk.com/ent...lease-v4-3-802
Site Sponsor
Old Aug 29, 2012, 01:07 PM
S11D336B's Avatar
Joined Apr 2006
v4.3.860
https://hoverflytech.zendesk.com/ent...pdate-v4-3-860
Site Sponsor
Old Nov 17, 2012, 02:28 AM
S11D336B's Avatar
Joined Apr 2006
Firmware Update
v4.6 released
https://hoverflytech.zendesk.com/ent...up-update-v4-6
Site Sponsor
Closed Thread
Discussion More Maxecuter Photo Updates Pat Daily Scale Kit/Scratch Built 5 Oct 28, 2010 05:03 PM
Discussion Maxecuter photo updates Pat Daily Scale Kit/Scratch Built 2 Oct 18, 2010 11:11 AM
Discussion More Maxecuter Photo Updates Pat Daily Scale Kit/Scratch Built 3 Sep 06, 2010 12:48 PM
Question Free wing rib softare? abenn The Builders Workshop 12 Aug 16, 2008 03:19 AM
