Old Jun 19, 2014, 02:18 AM
Allen adm is offline
Find More Posts by Allen adm
Joined Jun 2014
New Product
ARKBIRD-433UHF 10-channel module designed for long-distance flight
For long range FPV flight, Arkbird have produced this module and repeater station radio system compatible with all transmitters. You can either plug this transmitter into the module pins on the back of your PPM transmitter or use it as a repeater station by plugging it into any receiver[IMG]001.jpg[/IMG], making this the most versatile and easy to use unit for long range FPV flying. It has adjustable power output from 100mw-1400mw giving excellent range and operates on FHSS for effective frequency hopping.
Fully compatible with the Arkbird autopilot and OSD system, it can be connected via the 3 wire plug and gives full 10 channel functionality by converting the existing Ch 1-4 into Ch 7-10. This will also allow the Arkbird unit to control a camera gimbal with adjustable stability augmentation (Arkbird OSD firmware needs to be upgraded to v3.1020 or newer). This unit really is the easiest, most reliable and simple solution for long range FPV flight and because its made by Arkbird, you know it will work very well.
Features:
• Advanced FHSS frequency hopping system
• Adjustable power output (100mw-1400mw)
• Tuner and repeater modes
• No soldering required, just plugs into your model and transmitter
• 10 channel servo output
• Rapid 20ms radio link
• Compatible with Arkbird autopilot and OSD
• Compatible with ALL transmitters (via tuner or repeater modes)
• No programming knowledge needed, unit is plug and play
• Failsafe protection
• Included all hardware and antennas needed for operation
Specs:
Dimensions (Transmitter): 73 x 70 x 24mm
Antenna Length (Transmitter): 201mm
Weight: (Transmitter with Antenna): 116g
Dimensions (Receiver): 44 x 26 x 10.5mm
Antenna Length (Receiver): 155mm
Weight (Receiver with Antenna): 26g
Frequency: 433MHz
Radio Output: 100mw-1400mw
Power Input (Transmitter): 2-3s (7-12.6v)
Power Input (Receiver): 2-3s (4-12v)
Peak Current (Transmitter): 400mA @ 12v
Peak Current (Receiver): 120mA @ 5v
Range: Full Range
Includes:
10 Channel UHF transmitter and antenna
10 Channel UHF receiver and antenna
All necessary hardware
Foil tape for isolation of 2.4GHz interference (For use in repeater station mode)
Long distance flight video:
FPV Arkbird 433 60km 120km
FPV Arkbird 433 60km 120km (4 min 28 sec)
FPV Arkbird 433 50km/100km
FPV Arkbird 433 50km/100km (1 min 37 sec)
FPV Arkbird 433 36.5km/73km
FPV Arkbird 433 36.5km/73km (4 min 9 sec)
PS:Configuration is as follows
Talon plane.
ARKBIRD OSD
1.2g/0.7w high gain panel antenna
Arkbird 433UHF
20AH battery
To Pescadores Islands
Arkbird 433 fast response test(Analog Servo+Skywalker)
https://www.youtube.com/watch?v=MemB5x-kZv4uy
You can buy from Hobbyking.com,foxtechfpv.com and infinity-hobby.com :)
Allen adm is offline Find More Posts by Allen adm
Discussion ARKBIRD-433UHF 10-channel module designed for long-distance flight Allen adm FPV Equipment 0 Jun 18, 2014 02:21 AM
Help! Heavy lift & long distance flight X8 UAVMatt Scratchbuilt Multirotors 8 May 17, 2014 08:42 AM
New Product ArkBIRD 433UHF LongRangeSystem RC CONTROL rclab1 FPV Equipment 0 Jan 18, 2014 12:57 PM
Sold Reduced-JR PCM Trans-Module with 2-10 channel receivers for $20 unclegeorge Aircraft - General - Radio Equipment (FS/W) 2 Nov 01, 2013 04:13 PM
Idea Mouse trap car Designs for long distance alankyle Car Talk 1 Feb 18, 2010 01:02 PM
