Old Nov 26, 2013, 05:43 PM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
looked like it was dropping a wing - tip stall tendency?
The wing core was built with zero washout and flat as possible. On launch its a toss up if it drifts left or right for the first 40ft when my friend lets go, we haven't used the rail since the X brace riser on the front end of the bungee. I need to make my own so I can fly it more independently.
ApexAero is offline Find More Posts by ApexAero
Latest blog entry: no comment
Old Dec 02, 2013, 04:11 PM
ApexAero is offline
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Ergo working file .dxf
Enclosed is a working file for the Ergo, it is not structured or in any format or sheet just a raw dxf file for anyone to work with should they like to try and build one of these speed demons. You may need to adjust the cage diameter for your housing, Gary has a couple of nacelles as does Velocity-RC. I'm thinking of building a plug for a nice 70mm nacelle and 90mm nacelle following Clauses lead in design but with my twist of a straight cylinder area before and after the fan, in other words I extended the front of the housing by 12% and the rear by 75% shrouding the motor and to facilitate and area of even/equal velocity before it squeezes in the tail pipe efflux. I made quick change tail pipes using g-10 rings taped to the rear extension until I found the one I liked.
The cats out of the bag as to why its so quiet and works more efficient than other CS70 mm fans.
Old Dec 02, 2013, 08:29 PM
iron eagle is offline
Find More Posts by iron eagle
iron eagle's Avatar
United States, MA, Middleboro
Joined Jul 2007
Thanks for posting the file.
A tuned pipe for a df. !!!
iron eagle is offline Find More Posts by iron eagle
Discussion How to find CG on a Delta wing? mikes68charger Scratchbuilt EDFs 33 Apr 24, 2014 02:10 PM
Question flight-test-adjusting CG for speed on flying wing sloper Joe the Stack Flying Wings 4 May 26, 2013 01:58 AM
Discussion Why on earth do my plans say to set CG with the wing off? CNY_Dave Electric Plane Talk 4 Jan 20, 2013 05:37 PM
Question On a full size/scale aircraft what are the mini nacelle looking things on the wing? billiam2536 Modeling Science 5 Apr 28, 2008 02:50 PM
Where should the CG be on my new thing? Check out the pics. Sammy B Scratchbuilt Indoor and Micro Models 1 Nov 07, 2004 08:17 PM
