Old Jan 17, 2013, 11:01 PM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
calculations
Given a prop length, prop pitch, and rotation speed (rpm), what are the formulas to calculate the theoretical
- airspeed
- volume of air
- thrust
marhar is offline Find More Posts by marhar
Old Jan 18, 2013, 02:42 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
http://www.mh-aerotools.de/airfoils/index.htm
Look under "Propellers".
Steve
slipstick is online now Find More Posts by slipstick
Old Jan 18, 2013, 06:00 AM
Ken Myers is online now
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
Another good source here:
http://aircraft-world.com/prod_datas...p-proptalk.htm
Ken Myers is online now Find More Posts by Ken Myers
Old Jan 18, 2013, 12:54 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
jackerbes's Avatar
USA, ME, Ellsworth
Joined May 2008
The Powerplant calculators here will give most the useful info you're looking for:
http://2bfly.com/tools/
And if you are looking for info on specific motors with various props or specific props with various motors, the info at flybrushless.com is hard to beat:
http://www.flybrushless.com/
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jan 19, 2013, 08:40 AM
snoopy_schulz is offline
Find More Posts by snoopy_schulz
snoopy_schulz's Avatar
Germany, lake of constance
Joined Oct 2010
Another useful report (see attached file), but sorry in german language.
May use the google translater: http://translate.google.com/
I have written a propeller tcl script based on the document from Helmut Schenk.
Code:
# Michael Schulz 21.01.2012
proc calculate {} {
  global  Hz Dz np pin vp fp Prop N100
  set Kp 100.0
  set H [expr $Hz*2.54/100.0]
  set D [expr $Dz*2.54/100.0]
  if {($Prop == "APC")} {set Cp [expr 0.0856*($H/$D) - 0.0091]}
  if {($Prop == "AERONOUT-CAM")} {set Cp [expr 0.0833*($H/$D) - 0.0116]}
  if {($Prop == "Speed-Prop")} {set Cp [expr 0.116*pow(($H/$D),2)- 0.066*($H/$D) + 0.0467]}
  set n100 [expr 60*pow(($Kp/($Cp*pow($D,5)*1.225)),0.333)]
  set n100 [format %1.0f $n100]
  $N100 delete 0 100 ; #
  $N100 insert 0 $n100
  set Pin [expr pow(($np*1.0/$n100),3)*$Kp]
  set Pin [format %1.0f $Pin]
  $pin delete 0 100;
  $pin insert 0 $Pin
  set Vp [expr $H*$np/60.0]
  set Vp [format %1.1f $Vp]
  $vp delete 0 100 ; #
  $vp insert 0 $Vp
  set F [expr 0.785 * pow($D,2)]
  set S1 [expr 0.55*$Pin]
  set S2 [expr pow($S1,2)]
  set S3 [expr (2 * 1.225 * $F * $S2)]
  set Fp [expr pow($S3,0.333)/9.81]
  set Fp [format %1.2f $Fp]
  $fp delete 0 100 ; #
  $fp insert 0 $Fp
  set SD [expr $H/$D]
  if {($SD >= 0.9) & ($Prop != "Speed-Prop")} {tk_messageBox -icon error -message "Use Prop Style -> Speed Prop !"}
proc gui {} {
      wm minsize . 285 330
      wm title . "Propeller V1.0  M.Schulz"
      set a [labelframe .a -bd 3]
        set m1 [frame .a.m1]
        set f0 [frame $m1.f0]
          set lf0 [label $f0.lf0 -text "Prop Style: " -font {Arial 10 bold }]
          tk_optionMenu $f0.1 Prop AERONOUT-CAM APC Speed-Prop
          pack $lf0 -side left
          pack $f0.1 -side right
        pack $f0
       pack $m1 -fill x -pady 6
        set a1 [frame $a.a1]
          set al [label $a1.l -text {Prop Diameter ["] } -font {Arial 11 }]
          set ae1 [entry $a1.e -width 6 -justify right -textvariable Dz  -font {Arial 11 }]
          pack $al -side left
          pack $ae1 -side right
        pack $a1  -fill x -pady 5
        set a2 [frame $a.a2]
           set al [label $a2.l -text {Prop Pitch ["] } -font {Arial 11 }]
           set ae2 [entry $a2.e -width 6 -justify right -textvariable Hz -font {Arial 11 }]
           pack $al -side left
           pack $ae2 -side right
        pack $a2 -fill x -pady 5
        set a3 [frame $a.a3]
          set al [label $a3.l -text {Prop speed [rpm] } -font {Arial 11 }]
          set ae3 [entry $a3.e -width 6 -justify right -textvariable np -font {Arial 11 }]
          pack $al -side left
          pack $ae3 -side right
        pack $a3 -fill x -pady 5
      pack $a -fill y -pady 12
      set b [labelframe .b -bd 3]
        set b1 [frame $b.b1]
          set bl [label $b1.l -text {n100 [rpm] } -font {Arial 11 }]
          set N100 [entry $b1.e -width 6 -justify right -font {Arial 11 }]
          pack $bl -side left
          pack $N100 -side right
        pack $b1  -fill x -pady 5
        set b2 [frame $b.b2]
          set bl [label $b2.l -text {Prop Input Power [W] } -font {Arial 11 }]
          set pin [entry $b2.e -width 6 -justify right -font {Arial 11 }]
          pack $bl -side left
          pack $pin -side right
        pack $b2  -fill x -pady 5
        set b3 [frame $b.b3]
          set bl [label $b3.l -text {Static Prop Thrust [kg]} -font {Arial 11 }]
          set fp [entry $b3.e -width 6 -justify right -font {Arial 11 }]
          pack $bl -side left
          pack $fp -side right
        pack $b3  -fill x -pady 5
        set b4 [frame $b.b4]
          set bl [label $b4.l -text {Pitch Speed [m/s]} -font {Arial 11 }]
          set vp [entry $b4.e -width 6 -justify right -font {Arial 11 }]
          pack $bl -side left
          pack $vp -side right
        pack $b4  -fill x -pady 5
      pack $b -fill y -pady 20
      set bu [labelframe .bu]
        button $bu.1 -text "Calc" -command {calculate} -font {Arial 11 bold } -bd 3
        pack $bu.1
      pack $bu
########################## Main ###############################################
set ignore [catch {eval {wm iconbitmap . -default [file join snoopy.ico]}}]
global Dz Hz np
set Dz 14; set Hz 8; set np 5500;
gui
Download of the Propeller program:
http://snoopy-schulz.square7.ch/Propeller.exe
snoopy_schulz is offline Find More Posts by snoopy_schulz
Old Jan 22, 2013, 01:10 PM
marhar is offline
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
These all look like great resources. Thanks guys!!
Discussion Looking for info related to calculations, flying, etc. lardo5150 Beginner Training Area (Aircraft-Electric) 5 Jan 16, 2013 01:06 PM
Discussion charging calculations? is this right? cornholio223 Batteries and Chargers 12 Jan 12, 2013 10:09 PM
Question How to calculate sweep distance for CG Calculator? PDX Slope Pilot Slope 20 May 08, 2007 03:29 PM
Calculators and more calculators billystiltner Scratchbuilt Indoor and Micro Models 34 Mar 29, 2006 06:07 PM
