Old Jun 12, 2011, 08:36 AM
spessx is offline
Find More Posts by spessx
Texas
Joined Nov 2000
MCP X - The dreaded shakes
I can't get rid of the shakes on this thing. I've tightened up all the servos. I even sent it back to Horizon which took over a month. It flew good a few times then went right back to shaking.
The only way to pull it out of one of those shakes it to give it a lot of collective and throttle.
Any suggestions? I must be missing something.
-s
spessx is offline Find More Posts by spessx
Old Jun 12, 2011, 09:51 AM
Xrayted is offline
Find More Posts by Xrayted
Closed Account
Joined Dec 2007
-s
Common known issue from one of two sources......it can come from dirty servo contact strips if the heli has many flights on it. Cleaning them will help.
The more common issue which can show itself almost immediately is too much slop in the plastic swash/servo linkages causing the heli to go into a cyclic wobble from the 3 axis gyro. Solution is to tighten up the slop by slipping tiny o rings or spare canopy grommets over the swash balls then snap the servo linkage back on. The back elevator servo can be tricky but you may get the result you need by only doing the front two servo links.
Also, make sure you do not have your blades tightened down too much.
Xrayted is offline Find More Posts by Xrayted
Old Jun 12, 2011, 10:12 AM
spessx is offline
Texas
Joined Nov 2000
X,
Thanks for the response. I found the rubber band mod burried in another thread and it seems to have solved the problem. I basically just stretched a rubber band over the linkages on the blade grips and it tied down some of the slop. Flies smooth like butter now!
-s
Old Jun 12, 2011, 10:26 AM
chevell is offline
Find More Posts by chevell
chevell's Avatar
USA, CA, San Diego
Joined Oct 2007
X,
-s
Rubber bands work well, I made a post on using those awhile back.
I use -002 orings now because they look better and last longer. Zero play in the linkages is nice.
chevell is offline Find More Posts by chevell
Old Jun 14, 2011, 09:10 AM
mattk0 is offline
Find More Posts by mattk0
mattk0's Avatar
United States, MN, Apple Valley
Joined Jan 2004
Also the 'grommet mod' which I found here:
http://www.helifreak.com/showthread.php?t=292796
and
http://www.rcgroups.com/forums/showp...postcount=9688
I just made the change on mine last night and will test it out today if it fixes the shakes
mattk0 is offline Find More Posts by mattk0
Old Jun 16, 2011, 06:12 AM
mattk0 is offline
mattk0's Avatar
Joined Jan 2004
FWIW the grommet mod made a large difference for me and shakes have not yet come back about 5 flights! Look'n good
Old Jun 16, 2011, 10:58 AM
Hixbot is offline
Find More Posts by Hixbot
Joined May 2008
can someone give me a link to the "rubber band mod"?
Hixbot is offline Find More Posts by Hixbot
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15644 Mar 09, 2015 10:07 PM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 01:17 AM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
