Old Nov 16, 2010, 08:42 AM
dsawyer44 is offline
Find More Posts by dsawyer44
Joined Nov 2010
Tailerons
Do all of the foamy jets require tailerons? I started to build a h-29 jet and just found out you need a special radio that is able to move the tailerons through delta mixing. Is there a way around this problem, or should i build a different plane? Nothing is simple anymore.
dsawyer44 is offline Find More Posts by dsawyer44
Old Nov 16, 2010, 09:11 AM
KFC is offline
KFC
Find More Posts by KFC
KFC
Blue Foam Master!!!
KFC's Avatar
United States, KY, Hanson
Joined May 2007
You can get a delta or v-tail mixer that hooks into the reciever. That would keep you from having to purchase a special transmitter.
KFC is offline Find More Posts by KFC
Old Nov 16, 2010, 02:15 PM
knutb is online now
Find More Posts by knutb
Joined Nov 2008
It is possible to do mechanical mixing as well, for example: http://www.rcgroups.com/forums/showt...75#post9105549.
The above link was one of the first google hits for "mechanical delta mixer"; I'm sure you can find a lot more, once you know what you're searching for.
knutb is online now Find More Posts by knutb
Old Nov 16, 2010, 02:34 PM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
Not all jets require tailerons, some use regular elevator and ailerons.
Check this thread, page 14, post 199, for the X-7 Taurus. Plans are in my blog.
http://www.rcgroups.com/forums/showt...ue+wonder+jets
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Nov 16, 2010, 03:41 PM
chara is offline
Find More Posts by chara
registered foam addict
chara's Avatar
Munich, Bavaria
Joined Dec 2004
of course you could fly the H-29 with ailerons and elevator as well.
ailerons via torque rods operated by one servo for instance. the elevator would
then be made as one piece and operated by the other servo.
but...if you intend to stay with that hobby i can tell you from my experience that it is worth investing in a programmable transmitter (starts at about 80$). lot's of cool designs around here use tailerons/delta-mixer/v-mixer.
cheers
chara
chara is offline Find More Posts by chara
Old Nov 16, 2010, 11:10 PM
djacob7 is offline
Find More Posts by djacob7
Knife cuts foam like its steel
United States, CA, Fremont
Joined Jan 2009
This is the $3 mixer I use for my jets
http://www.hobbycity.com/hobbyking/s...idProduct=6321
djacob7 is offline Find More Posts by djacob7
All Moving Tailerons?: Ailevators? steve glass Electric Ducted Fan Jet Talk 3 Jun 04, 2001 08:26 AM
Tailerons PLEASE HELP!!!! Cosmic Shane Electric Plane Talk 4 May 18, 2001 12:55 AM
F15 Tailerons? jackcannon Scale Kit/Scratch Built 1 May 13, 2001 08:13 AM
F16 style Tailerons jackcannon Electric Ducted Fan Jet Talk 2 May 12, 2001 06:12 AM
F16 on tailerons only? E MAN Electric Ducted Fan Jet Talk 12 Apr 23, 2001 12:29 AM
