Old Oct 04, 2012, 09:24 PM
robert smithe is offline
Find More Posts by robert smithe
Joined May 2011
Fuselage measurement for previous post
The measurements for the fuselage - Just the foam part 138.5 cm
If you look back at posting # 86 in this thread you will find pdf plans for the whole plane. You can print various parts out in actual size onto many sheets of paper and use alignment marks to tape them together to make your own full sized plans
robert smithe is offline Find More Posts by robert smithe
Old Oct 05, 2012, 12:12 PM
bozo bozok is offline
Find More Posts by bozo bozok
Joined Sep 2009
pdf file converted the a4 format..I make the file a4..therefore, was a multi-page..
between the pages I needed to adjust the spacing exactly dead..
Thank you for the reply ....
cut the length of the body as a 138cm..only a portion of foam?tail length does not include?
not excluding the length of elevator?I hope I got it right..to 138 cm in length without elevator
bozo bozok is offline Find More Posts by bozo bozok
Old Oct 05, 2012, 12:19 PM
Joined Sep 2009
I took off the small printer at home..I need it for some reason was the a4 format..To join many pages separately..difficult to estimate accurately the length of the body..
for this reason I asked you the length in cm..
I apologize for my English incorrect..
Old Feb 10, 2013, 11:21 AM
Joined Sep 2009
I'm looking for plans dxf format..I want to cut the body and its parts cnc machine..
Do you have a plan dxf format for cutting cnc....
Old Feb 11, 2013, 02:33 AM
ian hall is offline
Find More Posts by ian hall
ian hall's Avatar
North East UK
Joined Dec 2003
If you email me:
ianhall99@hotmail.com
I have a dxf file which I used on my Roland vinyl cutter to print out full size.
Best Regards
Ian
ian hall is offline Find More Posts by ian hall
Old May 25, 2013, 12:17 AM
BravoGolf is offline
Find More Posts by BravoGolf
Spearheading an Alliance
BravoGolf's Avatar
United States, CO, Aspen
Joined Oct 2010
Havn't been here in a while....
I used to see wing cores for sale at some web site, can no longer find it?
Is there someone still making heptad wing cores?
BravoGolf is offline Find More Posts by BravoGolf
Old May 25, 2013, 12:44 AM
Glenstr is offline
Find More Posts by Glenstr
Glenstr's Avatar
Canada, AB, Lac La Biche
Joined Aug 2010
the site is no longer up but I believe you can PM Jeff here, his username is MWCores
Glenstr is offline Find More Posts by Glenstr
Old May 25, 2013, 04:05 AM
BravoGolf's Avatar
Joined Oct 2010
Great
Thanks for the reply.
Old Sep 19, 2013, 10:04 AM
efeksk is offline
Find More Posts by efeksk
Joined May 2013
dxf and dwg files attached
efeksk is offline Find More Posts by efeksk
Funniest thing I`ve ever seen... LOL bo@ti Submarines 2 Jun 28, 2002 07:11 PM
The smallest chopper I've ever seen. RookieOne Electric Plane Talk 1 Mar 14, 2002 11:23 AM
I have a gws pico servo that freaks out in the cold. Ever seen this? The Other Dave Power Systems 11 Mar 06, 2002 03:09 PM
Worst crash I've ever seen RD Blakeslee Electric Plane Talk 5 Feb 25, 2002 01:10 PM
