Old Mar 26, 2014, 12:03 AM
TechAdiya is offline
Find More Posts by TechAdiya
Joined Dec 2013
I also think it's a problem with cheap ESCs.. I also had the same problem with a HK 18-20A SS series ESC. With that, when I use a fully charged 2S ,( @ 8.20v ) The plane suffered from the same problems that you have.. But after I discharged the battery down to 7.99v, All runs well without issues.. I think the program of the ESC identifies a 2S battery when it's less than 8v. otherwise, it thinks that the battery is a super-discharged 3S, and activates the LVC. If you have the knowledge, programming the ESC with SimonK firmware will solve the issue in no time.. Thanks!
TechAdiya is offline Find More Posts by TechAdiya
Discussion HELP!!! Ailerons go to full deflection when connecting battery ChiTownFlyer Electric Plane Talk 12 Jan 12, 2014 02:45 PM
Discussion Rotor Beeping when connecting to ESC and Battery Amorgos Multirotor Power Systems 5 Nov 13, 2013 06:51 PM
Question Battery orientation matter when charging? 01Bandit Batteries and Chargers 8 Oct 05, 2013 07:32 AM
Discussion What matters when charging Li-Ion batteries? Capacity or Voltage? GreenAce92_v2 DIY Electronics 3 Sep 30, 2013 02:07 AM
Discussion GWS Formosa Urgent Help Needed-Strange Problems when battery Connected WeatherFlyer 3D Flying 5 Jan 05, 2008 12:43 PM
