Old Jun 15, 2002, 03:50 PM
urs
switzerland
Joined Dec 2000
hot spot c.g
Hello
urgent....I kneed the c.g for the graupner hot spot jet model
thanks
urs
urs is online now Find More Posts by urs
Old Jun 15, 2002, 07:54 PM
UK
Joined May 2002
Hi
I can't remember off hand the exact position og the C/G for the hotspot, i'll have to pop out to the work shop to check if you are really stuck. I know that it is measured from the root rib leading edge back around 130 -150 mm??. If you have the instructions to hand the C/G is indicated on the schrematic diagram on the back page of the manual. Note make sure this is correct, as I had a bit of trouble on the first flight of my hotspot, were as the tank is forward CoG and full it is alittle to nose heavy, and requires up trim, so try to get the tank as far back without fowling the U/C. Also have plenty of controll movments just in case, were around 5 - 8mm of up elevons from the trailing edge is generally the normal nuetral position.
Good Luck
Guybo is offline Find More Posts by Guybo
Old Jun 16, 2002, 03:00 AM
urs
switzerland
Joined Dec 2000
thanks
I found it....alll systems go
urs
Alert I/C powered Hot-Spot Alan Davies Fuel Jet Talk 2 Jan 14, 2005 06:24 PM
Seaplane Help Needed.....(C.G. problem???) mrtim Power Systems 6 Jul 09, 2001 11:17 PM
C of G procrastination inc Power Systems 12 Jul 01, 2001 05:17 AM
Does the specified C G change with heavier motor/batteries ? Al P Electric Plane Talk 4 May 22, 2001 05:25 PM
Twister C G location please Al P High Performance 2 May 21, 2001 08:46 AM
