Old Mar 02, 2005, 11:37 PM
Cincinnati Cin N.Knty, Ohio, United States
Joined Sep 2004
AXI 2212/26 screw size
Bought a axi 2212/26 and I am mounting it behind a firewall, the motor didnt come with any screws, does anybody know what size screws I need to mount it behind a fire, the screws will go into the shaft side of the motor.
chris8105 is offline Find More Posts by chris8105
Old Mar 03, 2005, 02:21 AM
New Out Of Box (n00b)
Joined Dec 2003
Chris, I believe it uses M3 screws. To find out what length you need, measure the thickness of your firewall in millimeters, and add 3 to that number. For instance, if you have a 5mm firewall, you need 8mm M3 screws. Ask for them at your LHS, they'll know what you mean.
KJ
guitarzan is offline Find More Posts by guitarzan
Old Mar 03, 2005, 04:57 AM
Joined Jun 2004
ace hardware has metric screws in all sizes for pennies,each. t.d.
tempe dave is offline Find More Posts by tempe dave
Old Mar 03, 2005, 11:55 AM
Joined Sep 2004
Thanks fellas
Fs,axi 2212-26 & Tmm18e-3ph Controler Dennis Everett Aircraft - Electric - Airplanes (FS/W) 8 Feb 12, 2004 06:27 PM
how to interpret motocalc result or AXi 2212/ 26 or 34 KasperE Power Systems 1 Jan 06, 2004 09:28 PM
AXI 2212-26 Motor best speed controler Warren Baker Power Systems 2 Dec 27, 2003 11:59 PM
Axi 2212/26 Motor New rdalcanto Aircraft - Electric - Airplanes (FS/W) 6 Dec 14, 2003 11:22 AM
PJS 3D550 vs Axi 2212/26 rdalcanto Power Systems 2 Dec 14, 2003 05:02 AM
