Old Nov 22, 2014, 09:56 AM
Simdor's Avatar
Joined Jan 2014
Control Board Setup-What am I doing wrong?
HobbyKing Multi-Rotor Control Board V3.0 Problem (1 min 36 sec)
I have done several ESC's throttle calibrations but it won't make the 4 motors spin up at the same time. Motor 2 and 3 starts as normal, but the first one starts at 40% throttle and the fourth motor starts at 50%. Also, the controls are all wierd. It's not only reversed, but the aileron is the yaw, the yaw is the elevator and so on...Would appreaciate some guidance.
The picture is the settings I used when I flashed it!
Simdor is offline Find More Posts by Simdor
Old Nov 22, 2014, 03:59 PM
reelflyt
Edmonton, Alberta, Canada
Joined Mar 2010
Hi Simdor.
For one thing the rudder is backwards . You arm to the right . Make sure all the trims are centered on the sticks . Then make sure all the soldered connection are properly done ,as
a bad solder connection can slow down the power going to the motors .
Have you revved it up and tried tipping it from side to side to see if the gyros are working properly ?
Sometimes the motors are slow to start up but work OK once flying .
Gordon
reelflyt is online now Find More Posts by reelflyt
Old Nov 22, 2014, 05:07 PM
Simdor's Avatar
Joined Jan 2014
The controls isn't the problem really. What troubles me is the motors spinning up at different throttle points. The gyros are working fine, even though they are incorrect. I've years of experience in soldering and even passed a class regarding soldering so a bad solder connection is unlikely.
I read some comments on the Hobbyking page and one guy had the exact same problem. He stated the board was faulty, but never confirmed it. I've tried to reach to him but with no success...
Old Nov 23, 2014, 06:42 AM
Simdor's Avatar
Joined Jan 2014
SOLVED
Captainkuk's firmware 4.7 Xcopter was "too new". I guess the board couldn't handle the firmware. When I flashed it with the oldest firmware it worked like a charm and flies quite good.
Discussion Okay I need help with this what am I doing wrong? UM p51d ApexpretadorGT Electric Warbirds 24 Nov 24, 2014 02:20 PM
Discussion What am I doing wrong? (video) shaunmed Aerial Photography 12 Sep 04, 2014 02:12 PM
Discussion First build, what am I doing wrong?? InterestedParty Scratchbuilt Multirotors 26 Feb 27, 2014 05:19 AM
Discussion First build, what am I doing wrong?? InterestedParty Scratchbuilt Multirotors 2 Feb 02, 2014 11:04 PM
Discussion GoPro 2 video cable not working? What am I doing wrong? Demo7 FPV Equipment 4 Jan 26, 2014 11:53 AM
