Old Nov 10, 2014, 03:23 AM
hampus's Avatar
Sweden, Stockholm County, Stockholm
Joined Feb 2010
Build Log
H Quad from AR Drone
Thought I would share my H Quad journey here.
So long story short, my AR Drone stopped working a couple of years ago and I just recently decided to build something more versatile and customisable, using the AR motors, gear ratio, battery....
I've got a DX6i radio so I want it to be on a 2.4ghz rather than wifi as well so I left all boards and cables out for now and will use a CC3D instead. Will also switch out the battery to a higher C rated one, as soon as I get the thing to work.
Here's a list of stuff:
4 AR motors
Brushless motors
14.5 W
35,000 rpm
AR Battery
3 cells
11,1V
1000 mAh
10C
ESC
4 x 30A ESC
Other
CC3D board
Spektrum DX6 Transmitter
Spektrum Receiver
Mobius
FPV Transmitter and Receiver
Here's a first look at the build (no electronics in place just yet). It's not in the smallest category since the AR props are quite massive so ended up on 240x280 or so between the prop mounts.
What do you think? Will it work?
hampus is online now Find More Posts by hampus
Old Nov 10, 2014, 05:45 AM
hampus's Avatar
Joined Feb 2010
Read another post here somewhere and apparently the little motors will be ok with just 10amp ESCs so I'll go for that instead.
Old Nov 10, 2014, 06:30 AM
hampus's Avatar
Joined Feb 2010
Here is a motor, gear (1/8.75) and prop.
Old Nov 12, 2014, 05:20 AM
hampus's Avatar
Joined Feb 2010
A first look at adding a Mobius prototype and battery. Also extended the little cables on the motors.
Will score the top plate so that the battery and camera strap doesn't have to go all around it. Will also sit the camera behind the bent-down front panel so that it's a little bit more protected.
Now I'm just waiting on most of the other parts.
Discussion Build a H Quad from a smashed AR Drone? hampus Multirotor Talk 5 Nov 07, 2014 07:40 AM
Discussion First Quad after an AR Drone youngti Multirotor Talk 9 Feb 21, 2012 02:23 PM
Help! nubie Q's : moving from AR Drone to 'Real' quad lesdit Multirotor Talk 3 Mar 27, 2011 04:46 PM
Discussion AR.Drone Quad Copter Talajouy FPV Talk 2 Nov 14, 2010 03:36 PM
