Old May 05, 2014, 11:32 AM
United States, TX, McKinney
Joined Aug 2012
Castle esc and Hacker A60-7xs problem and fix
Hi all,
I wanted to post this thread so that maybe I could save someone else wanting to pull there hair out!!
I recently purchased a Hacker A60-7xs and have had a time getting this motor to pull over half power with my Castle HV85 esc, but finally got it to function ok.
Long story short I had to revert back to version 3.27 FIRMWARE and change my MOTOR TIMING to LOW to get the motor to run above half power.
FYI--the newest current firmware claims to fix this problem. In my case it did NOT! I think that has been the case with others from what little info I could find.
---BEWARE I HAVE SEEN OTHERS POSTS THAT CLAIM THAT FLASHING THERE ESC WITH THE OLD FIRMWARE CAUSED THERE ESC TO BASICALLY LOCK UP AND BECOME UNUSABLE, MINE WORKED FINE NO PROBLEMS--------------THANKFULLY
The specs with those changes are as follows:
3DHS 71" Slick
Hacker A60-7xs/Castle HV85/Zippy 40c 8s/APC 19x10e
--1850 watts
--66 amps
The plane flies nicely with these specs, hover and pullout are not a problem at all.
I will say I feel as though the motor still did not open up like I thought it might. It just didnt sound like it was gaining the RPM's it should.
If anyone knows any other information on this topic or has a better solution please let me know.
Farmflyer01 is offline Find More Posts by Farmflyer01
Discussion Hacker A60-7xs and Castle esc problems Farmflyer01 3D Flying 0 May 04, 2014 10:17 AM
Sold Hacker A60-18L, Castle 110HV esc... rcdrum Aircraft - Electric - Power Systems (FS/W) 7 Jan 21, 2014 01:41 PM
Discussion Hacker A60-6XS with Castle ESC Mmarshall Castle Creations 9 Dec 11, 2013 08:21 AM
Discussion Hacker A60-6XS with Castle ESC Mmarshall 3D Flying 19 Dec 07, 2013 07:44 PM
Discussion Hacker A60-7XS - lock ring problem bossee Hacker Brushless 5 Jul 16, 2013 12:20 PM
