Titan 1200 Watt 60 Amp Power Supply
Big Batteries Require a Big Power Supply
Got Power?
The Titan 1200 sure does. This bad boy is capable of outputting 12-24V and 60Amps worth of juice. If you are parallel charging and find your current power supply running out of steam, then the Titan 1200 is worth a look.
The LCD screen shows you the Volts, Amps, Wattage, and Temperature of the unit. It has dual banana/bullet style connections and an EC5 power plug to connect to your charger. With 1200 Watts of power, you can connect multiple chargers at the same time. With an adjustable output voltage ranging from 12V to 24V, Titan will run even the largest 1000+ Watt chargers on the market. There is also a power meter indicator that shows the level of power output.
The unit features multiple cooling fans on the back and sides to keep it running cool even under high power output. Also, the Titan has built-in front feet to lift the unit to ensure airflow under the chassis. A standard PC style power cord with USA power plug is included. [RC Accessory]
Old Oct 17, 2013, 10:42 AM
Administrator
Jim T. Graham's Avatar
United States, TN, Nashville
Joined Mar 2002
This reminds me of a CB radio!
Jim T. Graham is offline Find More Posts by Jim T. Graham
Administrator
Old Oct 17, 2013, 10:47 AM
So. Cal.
Breaker breaker good buddy! Got your ears on?
mrforsyth is online now Find More Posts by mrforsyth
Old Oct 17, 2013, 11:57 AM
bacon and eggs
remvideo's Avatar
United States, FL, West Palm Beach
Joined May 2013
wow that's not a bad price either ! How many 4,000Mah 4s batteries do you think it could handle at once at 3a ?
remvideo is online now Find More Posts by remvideo
Old Oct 17, 2013, 12:54 PM
RCG Staff Member
Jason Cole's Avatar
Joined Oct 2003
You should be able to do 4 or 5 of those at a time at 3C charge rate.
Jason Cole is online now Find More Posts by Jason Cole
Administrator
Old Oct 17, 2013, 03:28 PM
Fly Low or you'll never know!
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
That's a sweet power supply!
Cory
RC4x4 is offline Find More Posts by RC4x4
Old Oct 17, 2013, 11:27 PM
Got Another Prop?
WadesRC's Avatar
United States, VA, Hampton
Joined Aug 2006
Trust me, You do not want to use the term, "Good Buddy" on a CB Radio these days.
Nice Power Supply!!!
WadesRC is offline Find More Posts by WadesRC
Old Oct 18, 2013, 08:48 AM
Joined Jan 2004
Hi Guys. Great overview. I had no idea this was happening. The Titan is monster PSU and is very accurate. We have another shipment on order and have 1 unit left in stock. Free shipping in the Cont USA.
Last weekend at the field I charge 2 5000 5S packs for my pattern plane at 30 amps using a paraboard. The Titan display was showing about 667 watts. The voltage display on the Titan and the FMA Powerlab 8 was almost identical. Same for amp draw, the PowerLab was showing nearly the same as the Titan display.
RC Accessory is offline Find More Posts by RC Accessory
Site Sponsor
Old Oct 18, 2013, 09:58 AM
Joined May 2004
Does it employ some type of PFC?
Sit-N-Fly is offline Find More Posts by Sit-N-Fly
Old Oct 18, 2013, 10:24 AM
Joined Jan 2004
Yes it is Active Power Factor Correction.
Site Sponsor
Old Oct 18, 2013, 10:28 AM
So. Cal.
From the manual...
Efficiency and PF numbers are quite good and would allow running at full output from a standard US 15A circuit.
Old Oct 18, 2013, 12:19 PM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Originally Posted by RC Accessory View Post
... and is very accurate.
What does this mean?
jrb is offline Find More Posts by jrb
Old Oct 18, 2013, 01:17 PM
Joined Jan 2004
It means that the unit is true to its specifications. There has been some posts about another 1200 watt 24V PSU that was not putting out 24V, it was like 23.x volts.
Site Sponsor
Old Oct 18, 2013, 01:30 PM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
So max @ 12 is about 720; and less than 50 amps max on 24?
How accurate is the voltage list on the display?
what does 28C mean as shown here?
Old Oct 18, 2013, 01:44 PM
Joined Jan 2004
@ 24V 50 Amp is the max. 1200 watts / 24V.
The PSU is very accurate, that was what my post previously was about.
That is internal temp reading. The display is in celcius.
See this picture.
http://static.rcgroups.net/forums/at...253-1200-2.jpg
Site Sponsor
New Product Titan 1200 Watt 60 Amp 12-24V Adjustable PSU RC Accessory Batteries and Chargers 10 Aug 23, 2014 06:56 PM
Sold Cell pro power lab 6 and e-fuel 1200 watt power supply ERGO60SX Aircraft - Electric - Batteries & Chargers (FS/W) 1 May 04, 2013 01:43 PM
Sold 57 amp 12 volt 684 watt power supply for charger***59.95 Shipped**** Lammergier Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 05, 2013 10:13 AM
Sold 57 amp 12 volt 684 watt power supply for charger***59.95 Shipped**** Lammergier Aircraft - Electric - Batteries & Chargers (FS/W) 1 Feb 01, 2013 02:10 AM
Sold 57 amp 12 volt 684 watt power supply for charger***59.95 Shipped**** Lammergier Aircraft - Electric - Batteries & Chargers (FS/W) 4 Jan 24, 2013 02:25 PM
