Old Nov 04, 2014, 10:03 AM
Zippin Here and There
Zippets's Avatar
United States, MI, Rochester Hills
Joined Aug 2014
what is the trick of arming this board ?
Zippets is online now Find More Posts by Zippets
Old Nov 04, 2014, 10:13 AM
I Void Warranties
goebish's Avatar
France, Aquitaine, Bordeaux
Joined Feb 2010
same "trick" as any other multiwii board:
low throttle (<1100Ás) and high yaw (>1900Ás)
or
low throttle(<1100Ás) and configured ARM AUX.
goebish is online now Find More Posts by goebish
Old Nov 04, 2014, 05:56 PM
sunk more than scorp
WitnessOnly's Avatar
Australia, VIC, Melbourne
Joined Jan 2010
Deleted: wrong forum :/
WitnessOnly is offline Find More Posts by WitnessOnly
Old Nov 04, 2014, 07:41 PM
Joined Oct 2014
Ok. I'm checking my quad. All travel is 125%. I have no dc voltage at the motor connector with the motor unpluged. And throttle all the way up.
Reed10 is offline Find More Posts by Reed10
Old Nov 04, 2014, 07:46 PM
Joined Oct 2014
That is a screen shot of arming the quad
Old Nov 04, 2014, 07:57 PM
I Void Warranties
goebish's Avatar
Joined Feb 2010
no wonder it doesn't arm, yaw is only 1840, should be 1900 at least, setup endpoints on your tx or use an aux switch to arm...
Old Nov 04, 2014, 08:03 PM
Joined Oct 2014
How do I change it to reach 1900?
Old Nov 04, 2014, 08:05 PM
I Void Warranties
goebish's Avatar
Joined Feb 2010
depends of your TX...
Old Nov 04, 2014, 08:06 PM
Joined Oct 2014
Ok I went to sub trim on my dx6i and increased Rudd to 50 so I would get 1905. It armed and is working. I'm so happy thank you very much. Will it fly properly like this or is there something else I should change?
Old Nov 04, 2014, 08:09 PM
I Void Warranties
goebish's Avatar
Joined Feb 2010
don't change trims or subtrims, your channels should show 1500 at neutral position, that's important.
go to travel menu and make sure everything is set to 125% with sticks at both ends (eg with yaw stick left then right).
Old Nov 04, 2014, 08:13 PM
Joined Oct 2014
Cool. I showed 125% but when I moved right yaw it showed 100 so I moved it to 125 and fixed. I can't thank you enough for your help. Words can't express my gradatude.
Alert BE AWARE hobbyking MultiWii NanoWii ATmega32U4 Micro Flight Controller USB/GYRO/ACC neobot Multirotor Electronics 119 May 15, 2014 10:11 PM
Discussion Hobbyking KK board VS MultiWii for a simple quad? carl1864 Multirotor Talk 7 Jan 03, 2014 02:47 PM
For Sale DSM2 ultra micro transmitter joker24458 Aircraft - General - Radio Equipment (FS/W) 2 May 30, 2013 07:44 AM
For Sale AR6400NBL DSM2 6Ch Ultra Micro Receiver Propnutz Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Apr 08, 2013 11:27 PM
Sold New EFLU4864 DSM2 6 Ch Ultra Micro AS3X Receiver BL ESC $50 shipped baddb1 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Jan 08, 2013 08:16 PM
