Old Sep 24, 2012, 06:50 PM
Joined May 2012
Help!
Weighing blades
What does everyone use to equalise the weight of blades? My replacement blades .for the PT25 differ by about a gram. Is it critical that they all weigh the same?
Noggy is offline Find More Posts by Noggy
Old Sep 25, 2012, 05:58 PM
Joined Oct 2009
Once pairs of blades are balanced on a pivot, it is unlikely they will weigh the same, even if cut from the same sheet as the density varies so much. It is the moment that's important which is mass x distance from the pivot. The should be about the same weight, but that can be adjusted with coats of paint, dope, or sanding to make them lighter.
Once they are about the same weight, pairs can be bolted together at the mounting hole and placed on a pivot, as shown in Rich's photo. Ideally they should be bolted to a plate which has a pivot in the middle, and holes for mounting the blades at the same radius as the holes in the autogyro's head. That way the moment of the blade is correct.
Next, the lighter blade can have varnish or tape added until it is balanced against the other blade.
You probably didn't want all this, but the balancing can be done with paint., dope, extra covering or tapes.
To illustrate that weight doesn't matter see
Single Rotor Blade Helicopter. (Experiment) (8 min 32 sec)
Lazygit is offline Find More Posts by Lazygit
Sold compact digital weighing scale NIB $55 shipped CONUS only pilotuku Aircraft - General - Miscellaneous (FS/W) 2 Jun 28, 2012 01:41 AM
Question Weighing Blades jossUK Mini Helis 8 Jul 31, 2006 03:09 PM
Sold 3 x Digital scales for weighing blades (grams) rodneybarrett Aircraft - General - Miscellaneous (FS/W) 7 Apr 20, 2006 08:00 AM
WTB: Gram scale to weigh heli blades Ninjak2k Aircraft - Electric - Airplanes (FS/W) 5 Sep 04, 2003 11:38 AM
My Aspire weighs 47.9 ounces how much does yours weigh? Ripley Electric Sailplanes 5 Jun 24, 2002 06:39 PM
