Old Sep 22, 2012, 03:53 PM
Illegitimi non carborundum
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Patching damaged sheeting - a brief tutorial
While repairing a badly damaged wing I've had several opportunities to patch holed sheeting. Here's my process.
1. Mark a simple geometric shape around the damaged area
2. Trim away the excess balsa, beveling the cut in the process
3. Using the side of a pencil lead, shade the opening onto a piece of paper
4. Take a minute to check the required grain direction for your patch
grosbeak is offline Find More Posts by grosbeak
Old Sep 22, 2012, 03:54 PM
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
5. Trace the outline onto the patch
6. Cut out the patch
7. Bevel the bottom edges of the patch
Old Sep 22, 2012, 03:55 PM
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
8. Glue the patch in place
9. Secure the patch while it's curing
10. Once it's cured, sand the patch flush if necessary.
Old Sep 28, 2012, 10:00 PM
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Next steps...
Mix some Deluxe Materials Model Lite filler with water to create a paste just a little thicker than water.
Apply some filler to a palette knife and dab it into the cracks.
Flatten it out with the palette knife.
Note that this mixture sets well and is very easy to sand, so applying a little extra is no big deal.
A couple of other products I'm using, both from Lee Valley Tools:
35K09.10 - Set of 12 Palette Knives in Case
99W73.38 - Sanding Sponge Assortment, pkg. of 10
Old Sep 29, 2012, 05:51 AM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
Looks good so far. It's always nice to take a plane that most people would write off and make it look good as new... and sometimes even better. Filler and sandpaper are one heck of a combo
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Oct 01, 2012, 10:29 AM
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
As mentioned, this filler is very easy to sand.
It did a great job filling the gap on the patch, and it fills small scratches very well too.
Cool A brief history of aviation UlteriorModem Life, The Universe, and Politics 0 Mar 30, 2012 03:25 PM
Wanted My 1.2G Patch for your 900MHz Patch timecop FPV Equipment (FS/W) 9 Mar 03, 2012 09:23 PM
Discussion Reapiring badly damaged sheeted foam wing Twizter68 The Builders Workshop 8 Dec 05, 2007 12:02 PM
Discussion how to repair damaged parts under sheeting? jinithith2 Composites Fabrication 7 Aug 26, 2006 12:42 PM
14 sheets slightly damaged depron 75 shipped Dennis Everett Aircraft - Electric - Airplanes (FS/W) 8 Jun 23, 2004 03:50 PM
