Old Nov 22, 2014, 01:19 PM
Crazy Dave's Avatar
United States, HI, Kaneohe
Joined Sep 2014
Wow, right on Lee. I didn't know you supplied all that misc. stuff in the kit. Thanks, that's makes it really easy.
Dave
Crazy Dave is offline Find More Posts by Crazy Dave
Old Nov 24, 2014, 03:55 AM
Crazy Dave's Avatar
Joined Sep 2014
Great day at the RC park with a new paint job.
Dave
Old Nov 24, 2014, 11:03 AM
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I really want to go flying with you. I really like your weather better!!!
Lee is offline Find More Posts by Lee
Old Yesterday, 09:58 PM
Joined May 2009
Alright, all built up and about ready to start mounting electronics, but finding that a lot of nose weight is needed (as you all predicted) to get a proper CG.
Total weight (everything but battery) is ~245 grams. Battery brought it up to about 290 grams.
Thinking about moving the servos way up, mounting them either under or in front of the wings. Don't love this idea, as it means longer pushrods--but I make those out of carbon fiber so they're pretty light. Also it means I am not "using" all of the servo wire--it will have to 'bunched up' near the receiver. Seems like a bit of a waste--but would probably help push the CG forward.
I still look at that rear fuselage and think a few clean holes through it would probably help remove a bit of weight without sacrificing much strenghth. I have a set of 'cork borers' (just sharp tubes, really) that would probably make a good clean cut.
Also planning on swapping out the "EZ connectors" that were included...I have some lighter ones. But this kind of stuff seems like drops in the bucket...
doughpat is offline Find More Posts by doughpat
Old Yesterday, 10:15 PM
swede
denial15's Avatar
United States, UT, Vineyard
Joined Aug 2005
When the bucket is hanging off the back end of your plane, every drop will help.
How far back do you have the main wing?
denial15 is offline Find More Posts by denial15
Old Yesterday, 11:42 PM
Joined May 2009
Nice analogy, Denial!
I've got the wooden rods mounted exactly as per the instructions (can't remember exactly where that is now--not in front of the plane).
I had read something about moving the wing forward--does that entail making a new slit and gluing in the dowels further toward the nose? If so, how much further forward?
Old Today, 08:57 AM
swede
denial15's Avatar
Joined Aug 2005
Yeah, the CG is relative to the position of the wing. I put my wing on last. I measure where everything goes and I adjust the wing to get the correct center of gravity. Once the CG is where it needs to be, then I do the slits and put the dowels on. My guess is you would just need to have the wing farther back.
Old Today, 12:57 PM
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Moving the wing back effects control on a rudder elevator control plane. It will still work but it is better to lighten the tail.
Found Sullivan/RnZ 36" and 48" foam float cores Comet1 Aircraft - Fuel - Airplanes (FS/W) 5 Oct 22, 2011 09:04 AM
Wanted Combat Wing 36 or 48 XE2 wbrannies Aircraft - Electric - Airplanes (FS/W) 1 Sep 18, 2011 04:17 PM
Sold WTT - 19" EPP Yaks - Great 3D indoor trainers. tonebone Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 13 Jun 01, 2011 08:40 PM
Off Site ITEMS END TODAY on Ebay..Gliders by XGDan EPP 36,48,60 inch Racer/DS slopepilot Aircraft - Sailplanes (FS/W) 5 Aug 17, 2010 01:55 AM
Sold EPP 1.3# Foam 36" wide x 48" long x 4" thick 2 sheets rakm Aircraft - General - Miscellaneous (FS/W) 3 Jan 24, 2007 08:49 PM
