Old Apr 02, 2011, 03:41 PM
marek rokowski's Avatar
Poland
Joined Aug 2009
New Product
My new kit: Me109F
hi
i want to say thanks for beltpilot -hi was inspired my by his thread:http://www.rcgroups.com/forums/showthread.php?t=1249494
so i just make my new epp kit Me109F in winter camuflage from JG54
wings span: 800mm
waight to fly: 370gr
equipment:
motor Emax 2812+ proppeler 8,x4
esc: 25A
battery: li-po, 3s 1350mAh
servos: - ailerons and elevator 3 x 5gram servos
reciever4 CH
i dont have to many photos from building because i maked this plane very fast
fuselage:
colectors:
some details:
and painting
t.b.c.
regards
Marek
www.napolskimniebie.pl
marek rokowski is offline Find More Posts by marek rokowski
Old Apr 03, 2011, 03:12 PM
Poland
Joined Aug 2009
today was very nice day
so, we maked some flights...
regards
Marek
Old Apr 12, 2011, 04:42 PM
Poland
Joined Aug 2009
How make fuselage? its easy!
1. If you don't have much experience in working with EPP – please follow the pictures to make it as easy as possible.
I. First
that aplies of course only if you want to make it as close to original one as possible – you can do it ”just about ” and it will not affect the flying performance.
- Find out the main shapes of the model
- Define the shape lines.
- Mark'em using a pencil
-Place the fusselage flat on the table and using sharp knife cut the edges off.
IMPORTANT: pull the knife toward you keeping it in angle 45deg. Avoid moving it forward and backward - one smooth move to get very straight surface.
II. Second
Apply more lines (green colour on the picture) and again cut the foam to get closer to your planned shape.
III. Smoothing
- Using sand paper - finnish shaping the fusselage.
Important: Do not press hard the sand paper to the foam – just minimum force!!!
IV. Finnishing
- You will nottice that after working with sand paper the surface is ”wooly” - to get rid of it you can use heat gun, or do it above the cooker
TIP!!!
If you hold the fusselage in front of a dark surface you will see better if this ”wooly” effect is gone.
We strongly advice you test that metod before on some spare piece of EPP.
Movement of the heater must be quite fast – do not hold it to long in one place !!!
You can also use an Iron.
this is part of assembly manual
(thanks for translations for Flying-dog from UK)
best regards
Marek
Discussion My new padded case for my new Futaba T8FG sharonx Radios 9 Nov 14, 2010 12:02 PM
Discussion Me109F for Mistel Project Harpye Scratchbuilt Indoor and Micro Models 7 Feb 14, 2010 09:36 AM
My brand new Corona kit is missing some tail rotor and swash plate parts...? rc_lurker Electric Heli Talk 8 Mar 08, 2005 02:32 PM
My new DF2004 with Airwolf kit and retracts Sydneysider Micro Helis 8 Aug 15, 2004 06:01 AM
pic of my new bashed kit! can you tell what it was? ttnissan Foamies (Kits) 14 Apr 20, 2002 04:05 PM
