Old Jul 15, 2015, 01:26 AM
Rcmatas is offline
Find More Posts by Rcmatas
Joined Jul 2015
Lil' Ripper 32" wingspan
Hello, today i want to show my first by my hands made plane. I have chosen from many plans, but Lil' Ripper was the best for me. I made it from 6mm depron and used a little of 2mm balza for motor mount and ruder's, elevator horns. I used "Kleiberit" glue for the all plane making, but it doesn't glue duct taped places, so the wing is not glued now, maybe there is glue which could do it? The body I coated with colored duct tape, but for the low quality it unstuck in several pieces of the body...
About the electronics. I used 2x digital servo e-sky for ailerons, 2x HXT900 9g for ruder and elevator(2mm carbon rod for struts). Motor - Emax CF2805 2840kv 29g, speed control - Mystery Pentium-30A, battery - Zippy 1000MaH 2S, prop - 8x6.
I think this system is a little bit weak, how do you think? Altough in the future i will update to 3S system.
So, what do you think guys about this plane?
There is some pictures:
And ofcourse first flight:
Rc plane flying and crash (Lil' Ripper) (1 min 21 sec)
Rcmatas is offline Find More Posts by Rcmatas
Old Jul 15, 2015, 11:18 AM
oceanway99 is offline
Find More Posts by oceanway99
oceanway99's Avatar
United States, FL, Jacksonville
Joined Feb 2012
nice job...looks a little tail heavy in your vid.
oceanway99 is offline Find More Posts by oceanway99
Old Jul 15, 2015, 12:10 PM
Rcmatas is offline
Joined Jul 2015
You are talking about the rudder or elevator or the all tail?
Old Jul 16, 2015, 05:56 PM
Russian Rebel is offline
Find More Posts by Russian Rebel
C.H.E.A.P
Russian Rebel's Avatar
Chino Hills, CA
Joined Oct 2010
I think what oceanway99 meant by saying tail heavy is that the CG (center of gravity) is in the wrong spot, the plane is pointing tail (both rudder and elevator) down too much and obviously when they say the plane is nose heavy - it means the nose of the whole plane is pointing down too much and you have to be on the up elevator all the time. I thick that what he meant.
Russian Rebel is offline Find More Posts by Russian Rebel
Old Jul 17, 2015, 04:08 AM
Rcmatas is offline
Joined Jul 2015
Hmm... Now i understand, thank you I think the CG is good, becose this plane has simple wings(it doesn't glide), so i always have to pull it up. But ofcourse i tested where the CG is and it was only 3cm not in the point by the plans, i think everything is good
Discussion **Lil' Ripper** by 3DMON DESIGNS 3DMON Foamies (Scratchbuilt) 1017 Jul 29, 2015 01:16 AM
Discussion Aerofilming with the lil-ripper 3d depron airplane nickden 3D Foamies 2 Feb 03, 2014 05:16 AM
Poll Yak or Lil' Ripper magnetus Foamies (Scratchbuilt) 1 Oct 16, 2013 02:03 PM
