Old Jul 11, 2015, 05:52 PM
scootrb4 is offline
Find More Posts by scootrb4
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
Robart valve trouble
Is it just me? I've been having leak-down trouble with the last couple of valves. I even put a seal kit in one and lost air in 15 minutes.
Is it possible I am adjusting them down to where they are too soft (slow) and that is causing problems?
scootrb4 is offline Find More Posts by scootrb4
Old Jul 11, 2015, 10:03 PM
dave steffan is offline
Find More Posts by dave steffan
Joined Aug 2012
Hi, check your air cylinders first.
When the retract system go's up or down the waist air from the retract cylinders expels through the valve. When the retract system is not being used it looks like the valve is leaking but its just slowly draining from the cylinders.
I had the same problem but after scratching my head for a couple of days traced it back to the cylinders.
For me i always make my complete retract system removable to trace leaks underwater.
Also a detergent froth and a paint brush painted round connections is an old trick.
I wire on all connections and pump mine to 120 Pounds.
Dave.
dave steffan is offline Find More Posts by dave steffan
Old Jul 12, 2015, 07:21 AM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
I use a Windex spray bottle for in plane tests. It has enough soap to make bubbles if there is a leak. I think I made some progress. It seems I reduced leaks by opening up the needle screw settings. Maybe a problem with having them too low (slow)? Will try again today.
Old Jul 12, 2015, 05:48 PM
aghost is online now
Find More Posts by aghost
United States, TX, Amarillo
Joined Mar 2005
I have a pair of extension connections so I can do leak checks with the wings off and the fuse open. I use Robart air lines which are transparent. Put a few drops of light oil in the air system, pump it up to pressure and watch the oil move. It heads for the leak.
aghost is online now Find More Posts by aghost
Old Jul 12, 2015, 09:02 PM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
Good idea
Old Jul 13, 2015, 04:20 PM
Joined Mar 2005
If you do the oil thing, it helps to cycle the gear a few times to distribute the oil throughout the system.
Old Jul 13, 2015, 09:47 PM
Joined Aug 2012
If the valve leaks after it has finished exhausting either the up or down air .
You can test with the bubbles, then the air bubbles can only come from one place and that is past the "O" rings in the retract cylinders.
Oiling may help.
On one of my aircraft where i needed maximum lift i ran the retract valve without the screws in.
Dave.
Old Jul 14, 2015, 12:22 AM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
Oiling may help.
Dave.
Oh - didn't know you could do that?
Old Jul 21, 2015, 01:32 PM
pretendpilot is online now
Find More Posts by pretendpilot
cuz real planes cost too much
USA, CO, Frederick
Joined Jan 2011
i had a similar problem but mine would NOT leak on the ground. i even tested after overnight without leak, but the system lost air pressure in flight (AHHH!) trying to trace it down, i did note that it occurred after i slowed the gear movement to very slow. so i adjusted them to go a little faster. that seemed to cure it.
pretendpilot is online now Find More Posts by pretendpilot
Old Jul 21, 2015, 03:23 PM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
Well, I have two of these valves now that of gone to ****. One I put new seals in last week. At the time it held, now it's leaking out of both ends ???
My flying buddy is having similar troubles with one of his valves.
We bought rebuild kits. Installed them with no luck
I have ordered a different brand of valve.
Old Jul 21, 2015, 04:15 PM
USA, CO, Frederick
Joined Jan 2011
well, at the risk of sounding like im insulting your experience, is your servo rod/arm pushing and pulling the actuator rod STRAIGHT in and out (no pressure sideways)? also, i read somewhere that you should (or was it should not?) go all the way to the stops (this may have been in the operating instructions for a different robart valve - green?).
i ordered a new one when i was having the problem, but haven't needed it. btw, the shaft on mine seems to have some minor scratches. not sure about that.
s what kind did you order?
Old Jul 21, 2015, 04:43 PM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
That's okay. I believe there is nothing to be gained by going hard against the stops.
I went with this valve here. I read it has 4 seals vs 3 so maybe a better way to chamber it? I hope, it's working now.
Old Jul 25, 2015, 07:02 PM
Cougar429 is online now
Find More Posts by Cougar429
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
Did you check the tank fitting itself? Robart seems to have a problem there.
Cougar429 is online now Find More Posts by Cougar429
Sold 3 #605hd robart retracts with tank,fill valve and control valve drh024 Aircraft - General - Miscellaneous (FS/W) 5 Sep 10, 2014 05:08 PM
Sold NEW! Robart Variable Rate Air Control Valve 167VR NIB theshield35 Aircraft - General - Miscellaneous (FS/W) 1 Feb 21, 2014 11:32 AM
Discussion Robart fill valve vs tire chuck mike3976 Fuel Warbirds 9 Feb 18, 2014 03:42 PM
For Sale Robart 551RS 85 Retracts and Valve thunder1 Aircraft - General - Miscellaneous (FS/W) 5 Oct 28, 2013 09:13 PM
Sold Robart Tri Gear Retracts with Air Control & U.P.3 Retract Valve ddavis60 Aircraft - Fuel - Airplanes (FS/W) 0 Oct 22, 2013 10:19 AM
