Old Jan 12, 2015, 07:28 AM
rhardy60 is offline
Find More Posts by rhardy60
rhardy60's Avatar
United States, MI, Zeeland
Joined Jan 2014
Question
What ESC to buy .
I'm looking at the SEAKING V3 brushless ESC 180A 6s Speed Controller for RC Boat or the Traxxas Spartan VXL6S Boat Marine waterproof ESC speed control . I'll be putting it in my Impulse 31 Deep-V model PRB4250l . witch one you think would be best , i'm leaning to the traxxas one ?
rhardy60 is offline Find More Posts by rhardy60
Old Jan 12, 2015, 07:37 AM
Sibe is offline
Find More Posts by Sibe
Joined May 2012
Seaking.
Sibe is offline Find More Posts by Sibe
Old Jan 12, 2015, 07:40 AM
rhardy60 is offline
rhardy60's Avatar
Joined Jan 2014
Originally Posted by Sibe View Post
Seaking.
any reason y ?
Old Jan 12, 2015, 08:04 AM
Sibe is offline
Joined May 2012
Long history of Spartan escs going poof at far less than their ratings, the newer versions are better but the Seaking is one solid reasonably priced esc with a great track record.
Lots of problems with the original Spartans actually burning holes in the hulls when the esc failed! Then Traxxas didn't want to admit there was a problem and warranty the things.
I believe the are(or were) a Castle esc and Castle no longer makes any boat escs at least for retail, they gave up last summer.
Old Jan 12, 2015, 08:10 AM
bill34207 is online now
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
+1 for the Seaking 180. They have been great ESC's and hard to beat for the $
bill34207 is online now Find More Posts by bill34207
Latest blog entry: Freewing 90 mm Super Scale F-16
Old Jan 12, 2015, 01:15 PM
rhardy60 is offline
rhardy60's Avatar
Joined Jan 2014
How do these hold up ? Dynamite DYNM3820 80A Brushless Marine ESC
Old Jan 12, 2015, 01:46 PM
rhardy60 is offline
rhardy60's Avatar
Joined Jan 2014
Never mind , I just purchased the Hobbywing Seaking 180A V3 Brushless Esc 30302181011
Old Jan 15, 2015, 08:08 AM
BHChieftain is online now
Find More Posts by BHChieftain
Joined Apr 2010
Hi,
Another +1 for the seaking marine 180A for your impluse upgrade to 6S. I have a setup guide for the impuse that covers setup, upgrades, prop selection, and a bunch of useful links, if you'd like a copy shoot me an email at jqhydro@gmail.com
Chief
BHChieftain is online now Find More Posts by BHChieftain
Old Jan 15, 2015, 08:24 AM
rhardy60 is offline
rhardy60's Avatar
Joined Jan 2014
Originally Posted by BHChieftain View Post
Hi,
Chief
Sent email
Old Jan 21, 2015, 09:17 AM
rhardy60 is offline
rhardy60's Avatar
Joined Jan 2014
OK , i got the Seaking 180 in today , the question is how u solder the wires onto the motor ? the esc wire is about 3 time thicker than the motor wires are ?
Old Jan 21, 2015, 10:00 AM
Sibe is offline
Joined May 2012
You need to solder on some bullet connectors. I use 5mm for my stuff. 5.5 and 6mm are also common for high volt, high amps setups.
Don't forget to put some heatshrink over them when you are finished soldering.
Old Jan 21, 2015, 10:08 AM
rhardy60 is offline
rhardy60's Avatar
Joined Jan 2014
It came with the bullet connectors , but the wires from the motor a real skinny , is this going to make thing run hot ? the wire on the esc are like 10 gauge and the motor wires are like 16 gauge
Old Jan 21, 2015, 12:36 PM
Sibe is offline
Joined May 2012
It will be fine, don't cut the motor wires though! Not sure what motor you have but the wire may be part of the actual winding in the motor, if so they will be covered in a lacquer insulation that is almost impossible to clean off and solder.
If they are kind of stiff they are probably part of the winding, if they are soft floppy silicone wire then you can probably cut them as they are probably soldered to the windings inside the can. No guarantees though!
Old Jan 21, 2015, 05:09 PM
rhardy60 is offline
rhardy60's Avatar
Joined Jan 2014
I have the proboat 31 v , motor is 1800kv the boat is not the v2
Old Jan 21, 2015, 05:16 PM
Sibe is offline
Joined May 2012
The two proboat motors I have here both have the wires as an extension of the windings.
One I know is 1500kv the other I think is 1800kv. They are the original? versions not the Dynamite, One is out of a first generation Geico I think.
My Aquacraft motors are the same way I have all 3 available kv of those.
Castle motors you can cut, have a few of those.
Question What ESC to buy? RCLud Power Systems 16 Oct 09, 2014 01:46 PM
Help! Where to buy Shrink Wrap like what's on TP Packs and Castle ESC's Dynomike Parkflyers 4 Jan 03, 2006 10:49 AM
What ESC to buy... gktkk Power Systems 5 Mar 18, 2002 06:04 PM
What ESC should I buy? iflyelectric Power Systems 1 Feb 24, 2002 12:06 PM
