Old May 04, 2014, 11:54 PM
ErcoupeEd is offline
Find More Posts by ErcoupeEd
ErcoupeEd's Avatar
United States, IN, Grabill
Joined May 2004
Real Flight 7 swap files problem for Hangar 9 Taylorcraft
Hi !
I installed a Hangar 9 clipped wing Taylorcaft into RF 7 from the Knife Edge website
It installed fine, but it does the dangdest thing. The engine cowling falls off as soon as the Taylorcaft is pulled up in the airplane select menu.
I have deleted, re-installed it, same thing everytime.!
Is there a fix for this???
It flies just fine, but having the cowling fall off is rather odd !
ErcoupeEd is offline Find More Posts by ErcoupeEd
Old May 05, 2014, 11:41 AM
Imageek2 is offline
Find More Posts by Imageek2
Bad command or file name
Imageek2's Avatar
United States, CA, Riverside
Joined Jan 2013
Check the switches on your controller. Some designers have things like that on a switch. There is a helicopter on the swap pages that the canopy falls off of immediately as well, took me the longest time to figure out there was a switch that made it fall off (and stay on).
Imageek2 is offline Find More Posts by Imageek2
Old May 07, 2014, 01:27 AM
ErcoupeEd's Avatar
Joined May 2004
Thanks!
A buddy of mine had the same problem.
Depending on what kind of Tx you use, it is a switch that does it!
It's a real head scratcher until you experiment and figure it out!
What got me was the engine underneath is fairly detailed!
Maybeit's for guys who like to fly without a cowling, you reckon?
Maybe I'll get my revenge and design one where the wheels fall off after takeoff and it won't land without crashing until you figure out how to make the wheels go back on in flight!
Wanted Hangar 9 used parts from 26cc Taylorcraft (H-9) wyldrydes2 Aircraft - Fuel - Airplanes (FS/W) 0 Apr 19, 2014 12:54 AM
Wanted Hangar 9 Taylorcraft windshield (version 1, 26cc) wyldrydes2 Aircraft - Electric - Airplanes (FS/W) 0 Mar 09, 2014 12:29 AM
Wanted Hangar 9 Taylorcraft motor12 Aircraft - General - Miscellaneous (FS/W) 0 Feb 21, 2014 10:35 AM
Sold Hangar 9 Taylorcraft clip wing version 1, NEW nero1156 Aircraft - Fuel - Airplanes (FS/W) 3 Feb 02, 2014 11:15 AM
