Old Aug 04, 2013, 06:55 AM
Tom Wright is offline
Find More Posts by Tom Wright
Tom Wright's Avatar
Joined Feb 2012
Download
CFL New entry level Single Rotor Autogyro PDF and links to pre cut parts and rotors.
The CFL (Crane Fly Lite) has an easy to remove 34 " diameter, three blade folding rotor, and clip on undercarriage for convenient transport and storage. The simple light weight airframe is robust and, designed to take the inevitable knocks that learning to fly a single rotor model often involves. Great attention has been given to the control characteristics, and slow flight capability, to help maximise the chances of success for the first time Autogyro pilot.
After the model was flown at a well known Autogyro event it prompted model enthusiast engineers to set up production facilities for the delta flex plate, all the required GF parts, and rotor sets, the availability of these components should aid a quick accurate build and, should eliminate a lot of the uncertainty often experienced by pilots building an Autogyro for the first time. This model is not a commercial project for me, as the build guide and drawings have been compiled and formatted in PDF to be available to all without charge, take a look and see what you think.
The contact details for blades and other prefabricated parts will be posted within the next week or so. Do post comments and questions on this thread as any interest in this fascinating branch of our hobby is always welcome.
Link to the Crane Fly Lite flex plate and GF parts kit supplier. http://www.coolwind.co.uk/
Link to rotor blades supplier http://www.ajblades.co.uk/
Tom
Tom Wright is offline Find More Posts by Tom Wright
Old Aug 27, 2013, 12:24 PM
Tom Wright's Avatar
Joined Feb 2012
The CFL build PDF above is now the fully updated edition .
Tom.
Old Sep 13, 2013, 11:56 AM
Tom Wright's Avatar
Joined Feb 2012
AJ Blades have now opened their web shop, and are now shipping high quality auto gyro blade sets for a variety of models including the Crane Fly Lite .
The pre production sets I have flown to date have performed very well and required little or no balancing .
Coolwind have now added more Crane Fly Light universal parts to their shop.http://www.coolwind.co.uk/
Tom.
Old Sep 24, 2013, 04:39 PM
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
Have built mine and maidened today.
Turnigy 2822/14 1450Kv (got them in a couple of planes, nice motors) 145W on a 7X4.5 with a 3 cell, also run nice with a 8X6 on 2 cells (may try that in CFL when flying nice).
MG9 Metal Gear for roll and a couple of 4.3g servos at backend.
6Ch HobbyKing Rx that works well with my FlySky TH9X.
Nanotech 1000mAh 3 cell.
Using a set of 450mm AJ Blades at required length, covered in thin tape weigh 23.8g each as fitted.
They do spin up nice with just a walk in a little breeze.
AUW ready to fly 16.7oz (475g) slightly over spec but close enough, my 10X10 Spruce has more cross section than suggested 12.5X6.5
plus motor is a little heavier than the suggested motor.
Deyrick
Del-Dredd is offline Find More Posts by Del-Dredd
Old Sep 27, 2013, 10:15 AM
Tom Wright's Avatar
Joined Feb 2012
A great job Deyrick ,thanks for posting the photos and info .
Tom.
Old Sep 27, 2013, 12:28 PM
PaulB is offline
Find More Posts by PaulB
Paderborn DE
Well done Deyrick, nice looking machine.
Now we need a real objective Auto-G vs. CFL comparison.
There must be hundreds of newly hatched AG pilots out there who have cut their teeth on an Auto-G who may now be looking to move on to their first 'own built'.
Paul.
PaulB is offline Find More Posts by PaulB
Old Oct 10, 2013, 02:04 PM
Tom Wright's Avatar
Joined Feb 2012
Paul
Sorry I missed your post ,I have been busy building and trying to keep up with Mickey's posts over on his thread.
I have already done the comparison you suggest as I have an Auto - G and of course a CFL . but am I waiting some independent comparisons as my view might be seen as biased.
My personal opinion is that the CFL has better low speed performance and the control response gives more time for beginners to work out what input ,or not, is needed next . Of course as with any first time auto gyro experience disorientation is a major obstacle to overcome, so again the CFL can give more time to figure things out if flown in reasonable conditions and at low speed fairly close in, this does depend on the pilot getting the trim right and using the throttle to achieve the desired result. From the practical point of view I can definitely say the rotors and flex plate on the CFL are very robust.
Tom.
Old Oct 12, 2013, 12:35 PM
Del-Dredd's Avatar
Joined Aug 2004
I would agree with Tom's comparison although no expert and I have not flown the AutoG since i finished the CFL.
The Auto G does fly faster at cruise and seems to handle heavier in the air, the CFL seems to float in comparison and can easily hover stationary in a small breeze.
I intend to try a set of AJ blades on my Auto G and see what it is like then, I know Tom has used them on his and liked them.
Deyrick
Old Oct 12, 2013, 06:33 PM
mnowell129 is offline
Find More Posts by mnowell129
Mickey from Orlando. Really.
Joined Nov 2004
In progress.....
mnowell129 is offline Find More Posts by mnowell129
Old Oct 13, 2013, 11:40 AM
jodini is offline
Find More Posts by jodini
AND FOR MY NEXT TRICK....!
jodini's Avatar
Omaha Millard, Nebraska, United States
Joined Sep 2004
Good to have you back Mickey!
Joe
jodini is offline Find More Posts by jodini
Old Oct 13, 2013, 03:40 PM
Joined Nov 2004
Just two servos and blades to go.
Old Oct 13, 2013, 06:16 PM
Tom Wright's Avatar
Joined Feb 2012
Mid or rear mounted servos ?
Old Oct 13, 2013, 07:04 PM
Joined Nov 2004
Mid, pull-pull per my usual practice. Spectra is easier to run than copper and lighter. Otherwise I'm following the instructions quite carefully.
I've found a few things in the plan that you may want to consider.
1) the instructions call for cladding the top of the mast on three sides with G10, but the diagram only shows two.
2) the cladding material seems to be missing from the head from the manufactured parts, or I was unclear about where to cut it from. There didn't seem to be enough material so I used some I had.
3) The routed parts are nice but confusing to identify because the PDF shows the parts not in the routed layout. The PDF needs an "as routed out" diagram to help identify.
4) It's easy to miss that the fin must have an angled cut on it for the elevator. This is confusing as generally the root chord of the fin matches the root chord of the stab for most "typical" designs. May be confusing to a beginner. Perhaps if the rudder/fin were drawn with the stab/elevator in side elevation view this would be a bit more obvious.
5) The exploded diagram on page 6 shows the relationships of the parts well enough but neither it nor the text seems to indicate if the fuse sides go "on" the fuse bottom or on the sides of the fuse. Printed build notes in black and white don't help much either, one has to to go the color version to see the grain patterns.
6) I couldn't find the GF plates to back up the landing gear screws in the routed parts.
7) I'm an aerospace engineer by training and I don't know what an Aquila airfoil is. Aquila is not a worldwide universal airfoil designation as far as I can tell. Simply provide an airfoil template.
8) It is very, very hard to tell where the blade shim goes, especially if you print the directions out in black and white.
9) The rudder tiller is nicely designed but seems over-engineered. Why not simply turn the rudder servo over and run a straight pushrod just clear of the stab to a normal horn on the rudder? Additionally the long run of unsupported wire is going to be spongy at best. If you are worried about the servo being struck just run the pushrod through a slot in the stab.
10) An overall model side view would be helpful.
Note that this are all minor, picky things, overall it's very nicely done.
Old Oct 13, 2013, 08:16 PM
Tom Wright's Avatar
Joined Feb 2012
The prototype was clad on two sides, and has been fine ,but cladding three or four sides would be OK .
The cladding for the front and rear of the mast is supplied as a a strip 6.5 mm wide by 6" long .
Fair comment this is because the prefabricated parts only became available after the PDF was completed .
Noted
Yes this is important , and should be clearer. Did not think of monochrome printing .
I used spruce off cuts on the prototype, which is the the most reliable solution, it looks as if the gf alternatives never made it to the cutter program.
I believe the Aquila coordinates can be down loaded from a university site in the USA . Details to follow.
Will have a look at that one,
9) The rudder tiller is nicely designed but seems over-engineered. Why not simply turn the rudder servo over and run a straight push rod just clear of the stab to a normal horn on the rudder? Additionally the long run of unsupported wire is going to be spongy at best. If you are worried about the servo being struck just run the push rod through a slot in the stab.
Fair comment, this arrangement was used to simplify the method used on the prototype ,but in retrospect the original method was better overall.
Noted
Mickey
Thanks for the informative feed back , your comments highlight how much work and attention needs to go into even the simplest of builds. Most plans or instructions invariably leave some things to the builders imagination and previous building experience so I hope the CFL PDF does meet a reasonable standard, for a none commercial design.
Your build has come on very quickly and is looking good I look forward to hearing how the work to complete the model goes.
Tom.
Old Oct 13, 2013, 08:28 PM
Tom Wright's Avatar
Joined Feb 2012
As a matter of interest this is how I mounted the elevator/ rudder servos on a CFL V2 , granted not as good as "pull pull" set ups but it keeps things neat and does work well .
Discussion New one design, 1 meter, entry level boat... Capt.Crash Sailboats 61 Jun 09, 2015 03:20 PM
Question Best entry-level mini quad rotor? RC360 Mini Multirotors 15 Aug 04, 2013 06:57 PM
Wanted Entry Level FPV Gear StickHack FPV Equipment (FS/W) 11 Apr 19, 2013 04:19 AM
Question The effect of coning on single rotor autogyros Norfolk Flyer Auto Gyros 38 Mar 13, 2009 04:28 PM
Discussion 10 gram single rotor autogyro - Micromonotwirl alfoot Scratchbuilt Indoor and Micro Models 6 Apr 09, 2007 10:01 PM
