Old Nov 20, 2012, 11:28 PM
mithrandir is offline
Find More Posts by mithrandir
TEAM FUTABA TEAM DURALITE
mithrandir's Avatar
Joined Nov 2004
General trends and 'splanations
can some of yuh'all comment on some of the basic configurations of an EDF power system and what the effects and reasons for said configurations might be?
For example... why would I choose a 65% vs a 85% exit area ratio?
What inlet areas would I choose for what reasons? Big inlet? Small inlet?
Round lips vs sharp lips? Diffusion (if any)???
I have heard the term "Eflux" used in the context of thrust....
Comments such as "Higher thrust with lower eflux".... is higher "Static" thrust what is meant?
thanks
mithrandir is offline Find More Posts by mithrandir
Old Nov 20, 2012, 11:37 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
That might take a small book!
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Nov 20, 2012, 11:41 PM
Justo23 is offline
Find More Posts by Justo23
right between the batteries
Justo23's Avatar
Farmington UT
Joined Jun 2010
Agreed, but i have also said before that all this info should be consolidated into a "Sticky" at the top of this forum for ease of access and elimination of threads like this one as well as my own "Thrust Tube" thread...
Just a hint, if anyone gets EXTREMELY BORED in the wee hours of the morning lol
Justo23 is offline Find More Posts by Justo23
Old Nov 20, 2012, 11:54 PM
Joined Dec 2008
Most of what I learned at first was just reading the threads and lots of searches. I don't think I made my first post for months after I joined. Just read.
Old Nov 21, 2012, 12:15 AM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Quick cover
smaller intake looks scale but wont feed the fan so makes for a long take off run
smaller exhaust is more efflux(faster jet stream) but less thrust so longer take off run but more top speed...make it too small and you loose both.
So if you have a light weight speedy design you can use the smaller holes
if its a bit heavy you will need more thrust so bigger holes...
very over simplified but that is the idea
turbonut is online now Find More Posts by turbonut
Old Nov 21, 2012, 12:30 AM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
thanks
first of all, you wouldn't pick an exit area that small (65%). that's way too small and will stall the fan out. 85% is much more sensible for all around flying. if you want a speed model that's only good in that part of the envelope, I may push that to 70%, but that's about it. if you want max all around performance, you want around 100% FSA intakes and 85% exhaust. if you want to go fast at the expense of a bit of low end performance, you would go 85% intake and 85% exhaust. what you don't ever want to do, is go less on the intake than the exhaust. that's a no no and sure fire way to a smashed up plane.
you always want to strive for a rounded lip and not a sharp one. remember that fans pull air in from all directions, not just in front, so you want the smoothest transition as possible. rounded lips mean maximum thrust. sharp lips create vortices that rob power as they hit the fan face. you'll hear this at work too, cause the fan will be noisy as hell. your inlet ducts should be perfect too. they should never change at angles greater than 3 degrees and should transition as smooth as possible. if they diverge too fast, it will cause seperation, which again leads to eddies and vortices, which leads to lousy performance and noisy fans.
another thing to consider, is how the inlet(s) get the air to the fan(s). if it's a single duct to a single fan, you don't have any problems, as long as you stick to that 3 degree rule. if it's a two duct to a single fan, you've got to plan a little. for example, you want the two ducts to meet as close to the fan as possible, but not so close that it creates eddies and vortices that rob power. for that reason, you should allow the ducts to meet within about 2 inches of the fan face.
as for efflux and thrust, it's pretty simple. thrust is the oomph behind the plane, or the way the efflux columb interacts with ambient air. static thrust is at its highest when the fan moves as much air as is possible. the problem with this, is that the velocity of the air (efflux) is relatively low. if we want to go faster, we've got to increase the pressure. to increase the pressure, we neck down the exhaust from 100% FSA to 85% FSA, for example. what this does is back up the air a bit, which increases the pressure. this increase in pressure also increases the velocity of the air. imagine a hose pipe with your finger on it, as opposed to water just pouring out. same effect. we can only do this to a point though, before the air backs up so much, that it stalls out the fan. anything less than 70% will stall out the fan. so, high static thrust is good for applications such as airliners, but not so good for F-16 like performance.
hope this helps a bit, for now.
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Nov 21, 2012, 12:07 PM
BillO is offline
Find More Posts by BillO
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
Why should bifurcated intakes meet close to the fan? A single larger pipe has less drag then 2 smaller pipes of the same area. So wouldn't it be best for the two intakes to meet as soon as possible, subject to the smooth transitions rule?
BillO is offline Find More Posts by BillO
Old Nov 21, 2012, 01:01 PM
RogueAce is offline
Find More Posts by RogueAce
Air Assassin
RogueAce's Avatar
United States, FL, Pompano Beach
Joined Oct 2012
Rich..VERY nice explanation. Simple and concise. BillO...The bifurcated ducts meeting shorter would create vortices just like meeting too close to fan. Also the 2 ducts create the pressure that Rich had described. These things are all A BALANCE. To get more of 1 aspect you give up some of another. Short distances can create the same turbulence as long ones.
RogueAce is offline Find More Posts by RogueAce
Old Nov 21, 2012, 01:17 PM
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
I like them to meet as far from the fan as possible but not to make large angle changes..if too close to the fan the air cant swirl to meet the blades
Old Nov 21, 2012, 04:53 PM
Joined Jan 2009
yeah, everyone's got their own oppinions and methods of doing things. it's what makes this hobby so great. we can always learn something off each other.
Old Nov 22, 2012, 06:28 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
I'm not gunna argue with Stu!
http://www.rcgroups.com/forums/showt...t#post16274544
Odysis is offline Find More Posts by Odysis
Question Power System Trends-More Watts or Less R.M. Gellart Electric Competition Soaring-F5J/ALES/e-Soaring 81 Oct 06, 2012 09:29 AM
Discussion LOL I am seeing a trend here! UlteriorModem Life, The Universe, and Politics 22 Jul 22, 2012 08:46 PM
Rave New trend ; turn your dead pet into a quad cmulder Multirotor Talk 16 Jun 07, 2012 12:38 PM
Question Backorder Trend Wingbreaker Vendor Talk 0 Apr 16, 2012 05:34 AM
