Old Jan 17, 2011, 06:01 PM
crappie depot is offline
Find More Posts by crappie depot
crappie depot's Avatar
Michigan
Joined Jan 2011
hello
New to this fourm, hello.
crappie depot is offline Find More Posts by crappie depot
Old Jan 17, 2011, 08:31 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Welcome to RcGroups. I assume that you are interested in rc hovercrafts.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jan 18, 2011, 12:46 PM
Michigan
Joined Jan 2011
Indeed
Yes I am.
Old Jan 18, 2011, 01:50 PM
Joined Nov 2007
Have you built one before? If not, do you want to build one? If so, what gear do you have?
Old Jan 18, 2011, 02:45 PM
Michigan
Joined Jan 2011
Yes I have built several hovercraft. This one is made of carbon fiber and uses an O.S. .46. with a 10'' prop.
Old Jan 18, 2011, 06:52 PM
Joined Nov 2007
Well you are ahead of the regular new member. I should be asking you for help! lol
Old Jan 18, 2011, 07:36 PM
Michigan
Joined Jan 2011
Exp.
I've been into R/C for a long time. I've done cars, and built seven airplanes. I always wanted to build a hovercraft since I was a kid. My first model was made of balsa ply with a shower curtain for the skirt. I crashed it, built another. Then I started getting visions of intergrating pink foam with balsa and laminating with fiberglass so I built another, did all the plans in CAD. I let a friend try it out, he crashed it full speed into a parking lot divider. So I built another one. After that I started looking into fiberglass molding... how to make plugs and molds, releasing agents blah...blah... So I did some reasearch and desiged a CAD model then built one made of fiberglass with a bag skirt. It worked good, but I wanted it to be lighter so I made one out of carbon fiber using the same mold. I went to school for vehical design, there I learned flat pattern layout which helped me design skirts. I learn to use a sewing machine in middle school. I put all my tools together and came up with this hovercraft. Improvements to make: -I want to run the propeller with a belt drive. Doing this will lower the center of gravity. -Would also like a multi-bladed fan.
Discussion Hello! Davey NY Electric Plane Talk 8 Sep 09, 2010 02:27 PM
Discussion Hello Hello Is Anybody Out There.I'M Looking For Plane r/c4me SLMAC and RC Park (Arizona) 1 Aug 18, 2009 11:13 AM
