Old May 25, 2011, 04:13 PM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
I just do all that associated maintenance when I smash out the gearbox with an awesome biff...
CNY_Dave is offline Find More Posts by CNY_Dave
Old May 25, 2011, 04:16 PM
ridgewalker is offline
Find More Posts by ridgewalker
The lunatic is on the grass
ridgewalker's Avatar
Joined Aug 2008
Yeah your right i took a second look and it would be close.
I would give it a try as it is..before adding any cf rod.
A bit of flex on a nose in isn't all that bad..long as it's not to much,it can help save things..imho..longs as it doesn't move (the gear box) when you run/fly it.
Ridgewalker
ridgewalker is offline Find More Posts by ridgewalker
Old May 25, 2011, 04:25 PM
Kamov is offline
Find More Posts by Kamov
Kamov's Avatar
CA
Joined May 2007
yes on a new gearbox you woun't have to do that as the 4 pins are intact just leave it there
on mine all 4 had almost broken off after numerous dismounts so i decided to chuck it out.
If you can find smaller nylon bolts than what i used i think it might work if its spaced near the edges of the mount.
Kamov is offline Find More Posts by Kamov
Old May 25, 2011, 04:44 PM
Kamov is offline
Kamov's Avatar
CA
Joined May 2007
Removeable Champ Wing
Also experimenting with a removeable Champ wing using nylon bolts[and micro neo magnets under wing]
this is not for maintenace reasons but I'd like to bring the champ and stock tx with me on a smaller box basically make it more transportable than it is.
Old May 25, 2011, 05:46 PM
FlyingRtard is offline
Find More Posts by FlyingRtard
United States, FL, Jacksonville
Joined May 2011
Ok, I'm looking for a magnet expert here. Is there any magnets strong, yet light enough to hold a champ wing on all by themselves? Say one on each four "corners" of the champ wing attachement point? I've seen really strong and small magnets. And I think it'd be great to have a "pop able" wing. Just imagine how much damage you could save by havingnthat wing just POP OFF in a bad crash!!!!!
Now that's a mod I want but I don't wanna order magnets without knowing what may do it.
FlyingRtard is offline Find More Posts by FlyingRtard
Old May 25, 2011, 06:15 PM
Kamov is offline
Kamov's Avatar
CA
Joined May 2007
Kyosho Arium series micro beaver uses magnets alone to hold the wing but the a/c is probably designed for scale flying no hard aerobatics.
Im pretty sure Kyosho had tested them and they hold up
make sure you use neodymium magnets and not any other type like cobalt-samarium although strong but not as strong. If you fly scale you'd be alright but if you fly loops, dives, mild or wild aerobatics, I'd put a bolt in there.
heres a link of magnet source that I've ordered from
http://www.rcdude.com/servlet/the-Ac...ets/Categories
Old May 25, 2011, 06:43 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
There are many grades of neodymium magnets. I suggest N50 or N52.
Joel
turboparker is online now Find More Posts by turboparker
Old May 25, 2011, 06:56 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Magnets would be fine to hold the Champ wing on. It's only aileron wings that magnets get tricky, because a crash rips the servo wires out of the RX.
K&J magnetics sells a bunch of very powerful, small magnets. 8 would work best (4 pairs), 1/8" diameter is more than enough.
To install them, carve a pocket out of the foam, and use 5 minute epoxy, in the hole and smeared in a thin layer over the magnet. I also use clear plastic to smooth the epoxy on the magnet and to ensure the proper polar oreintation of the magnets after the epoxy has set up a little.
You don't want to glue the magnets on and find out hey repel each other.
UNGN is offline Find More Posts by UNGN
Old May 25, 2011, 07:47 PM
The Hog Pen is offline
Find More Posts by The Hog Pen
Go Ugly Early
The Hog Pen's Avatar
Azle, TX
Joined Oct 2010
I still want to make an EDF Champ...especially now that I got my 2 bricks back from chimchim.
The Hog Pen is offline Find More Posts by The Hog Pen
Old May 25, 2011, 11:24 PM
mutha is offline
Find More Posts by mutha
RC Airplane (Recently Crashed)
mutha's Avatar
Australia, VIC, Melbourne
Joined Jan 2011
You will need more than booger wheel nuts on that one!!!!
mutha is offline Find More Posts by mutha
Old May 25, 2011, 11:26 PM
Go Ugly Early
Azle, TX
Joined Oct 2010
I had to read that one a few times before I remembered what you were talking about...lol
Old May 26, 2011, 10:52 AM
jlcamp7 is offline
Find More Posts by jlcamp7
RC Logger Support
jlcamp7's Avatar
United States, WV, Hurricane
Joined Jan 2010
Really nice idea Kamov. The gear box mount is also a nice idea as well. These seem like extremely usable/doable upgrades.
I've more than a few times almost placed an order on some small magnets to use to hold the fuselage together, so when I got a new fuselage I could do magnets instead of the ugly old tape, plus it would give quick and easy access to the brick, motor etc. I had seen it done on the p-51 and sukhoi, but was afraid to try it on the Champ due to it being a high wing. I wasn't sure if the magnets would be able to handle the g's that from the wing when doing loops and rolls, or if it could handle them then it would be such a strong hold that I couldn't get the plane back open without damaging the foam.
I still would really like to do this, so if anyone ever tries this or experiments with it let me know. I would really like to make it happen on my champ.
Keep us updated on the things your doing Kamov. I really like the mods and if they work out well I will definitely be adding them to my plane.
Where did you get the tiny nylon bolts from? And also what size magents are you planning to use on the wing?
jlcamp7 is offline Find More Posts by jlcamp7
Old May 26, 2011, 11:12 AM
rc crashburn is offline
Find More Posts by rc crashburn
SUPERB RC CRASH MASTER
rc crashburn's Avatar
Houston, Texas USA
Joined Aug 2004
I don't think holding this plane together with magnets alone is the best idea.
I do like the idea of a threaded nylon stud, w/washer, and nut idea. VERY good idea!
Also a good idea for front & rear locating pins to align the wing to the fuse.
I'd cut off the taper on a toothpick and make each pin go into the ajacent foam about 1/4 inch (6mm).
Would be so cool to take the wing off & put our Champs into a MUCH more compact box
rc crashburn is offline Find More Posts by rc crashburn
Old May 26, 2011, 05:25 PM
Kamov is offline
Kamov's Avatar
CA
Joined May 2007
first of thanks to all that are putting their ideas or adding to the pot
UNGN
TurboParker
rc crashburn
Ridgewalker
I've learned a LOT[too many to mention] from previous posters that shared their mods here so this is just a tiny contribution im putting in here... but of course your all welcome
jlcamp7
those are just hardware store items, not sure what hardware store you have in your area but Lowe's, HD, have them almost sure. but i think i got mine from Ace Hardware or a specialty nut/bolts store is one source.
the magnets I have not installed them yet but i got them from rcdude.com
he has several sizes and strength the "N" rating not sure how that works but turboparker above had suggested one.
Im still building the champ and have not flown it yet. I like the idea of magnets holding the fuselage but im afraid it might not hold the way I fly the Champ especially with a SuperTurboCharged Methanol/Water Injected motor on it !! [a Bravo SX motor]
Its got way too much horsepower on it but hey whos complaining !!
thats a good idea and might just do that !
yup nice small box put it in a backpack ....exactly !
Old May 26, 2011, 05:55 PM
monboy10 is offline
Find More Posts by monboy10
Enough Power? -NEVER ENOUGH!
monboy10's Avatar
North-Eastern Saskatchewan, Canada -Eh?!
Joined Apr 2008
awhile ago someone posted a video of how to do foam hinges with a dinner plate. could that person please post it again?
monboy10 is offline Find More Posts by monboy10
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 01:09 AM
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 888 Dec 01, 2013 12:11 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 01:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 10:01 PM
