Old May 04, 2015, 12:33 PM
Utkinpol is offline
Find More Posts by Utkinpol
Joined Apr 2015
Telemetry via Taranis x9d external module?
Hi,
I am very new to Taranis, literaly just received this unit today.
I plan to use it with a x8r 16 channel module.
What I totally fail to understand is the actual set of limitations that x8r module has in regard of passing and transmitting telemetry.
I look at the samples of those hook-ups, for both APM and PixHawk - I found youtube showing how to flash APM to understand X8R protocol commands directly without additional transcoder module. PixHawk is a plug and play, so far so good.
I also got Teensy board to pass telemetry into X8R. Ok here too. That is how it goes onto Taranis screen.
What I do not understand is how we need to deal with a regular connection to mission planner software. Typical interface would be done via 3dr 915 MHz telemetry kit but it seems a bit retarded as we now have x8r in place.
Looking at the worst case scenario I see now that a same telemetry signal will need to go to MinimOSD, to 3dr 915Mhz telemetry transmitter AND to Teensy board and then into X8R.
Is there a way, any way, to use Teensy and X8R alone and then feed this signal into Taranis radio and then from extension port on Taranis into any local destination such as Mission Planner or anything else? Or for now we have to support 2 transmitters for same data? It looks odd.
Or am I missing something? Wasn`t Taranis supposed to be able to support telemetry receive/transmit both ways? What do I miss?
Utkinpol is offline Find More Posts by Utkinpol
Old May 04, 2015, 11:13 PM
Utkinpol is offline
Joined Apr 2015
Not a single response in a whole day? Is it really such an unsolvable problem?
There are no embedded systems engineers here who have Taranis and can explain details of the data stream it utilizes?
Old May 05, 2015, 01:29 AM
chly3001 is online now
Find More Posts by chly3001
Singapore
Joined Apr 2014
i'm no expert but for one i know for sure a day isn't a long day at all to wait for an answer to a problem.
as far as i know the taranis (or frsky in general) does not do connections to mission planner. u will still need your 915/433 radio to do that. so yes most of the time there are many radios on the copter. 2.4ghz control link, 5.8ghz video downlink and 433/915 telemetry to computer
chly3001 is online now Find More Posts by chly3001
Wanted FrSky 2.4GHz ACCST TARANIS X9D Digital Telemetry Radio System (Mode 2) colby_attack Aircraft - General - Radio Equipment (FS/W) 3 Mar 03, 2015 08:41 PM
Sold Taranis X9D Tx, and X8R Telemetry Rx ptuxbury Aircraft - General - Radio Equipment (FS/W) 3 Jan 22, 2015 11:57 PM
Sold 3DR Iris Samsung S3 3DP Stowable Telemetry Caddy for the Taranis X9D and FrSky TH9X ShokWaveRider Aircraft - Electric - Multirotor (FS/W) 0 Dec 24, 2014 01:46 PM
Sold FrSky Taranis X9D 8/16ch Telemetry Radio Transmitter, RX, Neck Strap & Charger hadawayj Aircraft - General - Radio Equipment (FS/W) 14 Dec 27, 2013 08:38 AM
