Old Dec 26, 2014, 06:33 PM
GreatMonk is offline
Find More Posts by GreatMonk
Joined Jan 2012
Help!
quadcopter size 450 flight time so short
Hi friends..
please somebody help me..
I have a quadcopter ( reptile aphid ) size 450 and i dont use that stock servo gimbal.
i already upgrade to :
Motor : sunnysky 800kv
props : graupner 10x5
esc : multistar 30a
Board : naza m lite + gps
gimbal : goodluckbuy gimbal brushless
cam : sjcam4000wifi
vtx vrx : boscam 200mw
batt : 3s 5000mah
overall weight : about 1800g
i have a problem with my flight time with this setup..
I can only flight 2 - 3 minutes...
please help me...how can i increase my flight time to maybe approximately 10-15minutes if possible?
How should I do...
thanks,
GreatMonk is offline Find More Posts by GreatMonk
Old Dec 26, 2014, 06:56 PM
waltr is online now
Find More Posts by waltr
Team WarpSquad
United States, PA, Doylestown
Joined Jan 2014
800kv and 3S?
At what throttle does it hover?
Did you plug your parts into Ecalc?
waltr is online now Find More Posts by waltr
Old Dec 26, 2014, 07:02 PM
Joined Jan 2012
Originally Posted by waltr View Post
800kv and 3S?
Yes i use 3s 5000mah..
is that wrong..?
what recommended batt for sunnysky 800kv?
or maybe any advice..?
It hover at about 55% throttle stick..
What is ecalc?
sorry.. but im new in multirotor..
Please help.....
Old Dec 26, 2014, 07:09 PM
waltr is online now
Team WarpSquad
Joined Jan 2014
Google "ecalc" and then you will know.
Old Dec 26, 2014, 07:18 PM
Joined Jan 2012
Done, i already input my spec into ecalc n found the result..
it said that hover at 80% throttle and flight 7-8 minutes..
what happen with my quad.. why only flight 2-3minutes..
Old Dec 26, 2014, 07:48 PM
waltr is online now
Team WarpSquad
Joined Jan 2014
Was the battery fully changed?
Did you run the battery down to 20% of capacity (use 80%)?
Hovering at 80% throttle means there is not enough power. Check to see if a 4S battery works better.
Old Dec 27, 2014, 01:41 AM
Joined Jan 2012
Yea fully charge..
i use buzzer at 3.6
and after my quad landing. I check voltage was 3.6
so sad..
Old Dec 27, 2014, 08:12 AM
waltr is online now
Team WarpSquad
Joined Jan 2014
How much additional current does the gimbal and vTX draw? These will shorten the flight time if powered from the flight battery.
Old Jan 04, 2015, 12:07 AM
Joined Jan 2012
Waltrthanks for helping me..
i separate my primary batt with gimbal batt..
and now i get 8-10minutes..
thankyou so much for your advice..
Is that possible for quad size 450 to have a flight time more than 15minutes?
i calc with ecalc.. i think thats impossible because i must use 16" props.
arm of quad only 45cm..
Old Jan 04, 2015, 12:36 AM
Made in Austria is offline
Find More Posts by Made in Austria
Made in Austria's Avatar
United States, NV, Las Vegas
Joined Dec 2013
What brand and model is your battery, and what's the "C" rating of your battery?
Made in Austria is offline Find More Posts by Made in Austria
Old Jan 04, 2015, 02:35 AM
sooraj.palakkad is offline
Find More Posts by sooraj.palakkad
Joined Aug 2014
Well C rating or Discharge rating of battery need to be considered, . If it is not sufficient to provide to the current consumption of your quad, it will discharge very fast, also flying like this is not safe. Do the battery get Hot after flying ?
sooraj.palakkad is offline Find More Posts by sooraj.palakkad
Old Jan 04, 2015, 03:24 AM
Ira NZ is offline
Find More Posts by Ira NZ
Bombs away! Err...landing
Ira NZ's Avatar
Upper Hutt, New Zealand
Joined Apr 2006
That shouldn't give you 2-3 times the flight time. The draw of a VTX and gimbal is usually only a fraction of the motor draw, people usually find no increase in flight time or even lose it using a second battery.
Ira NZ is offline Find More Posts by Ira NZ
Old May 09, 2015, 10:08 PM
c4pnk1rk is offline
Find More Posts by c4pnk1rk
Joined Jan 2015
I know I'm bringing back an old thread here, but if your gimbal was pulling that much battery its likely you have your PIDs set too high on the motors. If you can get super wild with it and it stays rock solid, then you can lower them down some. You should still be able to "bump" it with your finger and have it move without acting like its being superman holding your camera.
c4pnk1rk is offline Find More Posts by c4pnk1rk
Question Short flight times with my Hubsan x4 SiGone Mini Multirotors 4 Jan 06, 2015 07:18 AM
Help! DJI s900 Short Flight Times - Batteries? silvertip Batteries and Chargers 3 Nov 07, 2014 06:23 AM
Discussion Short flight time problem tnemura Multirotor Power Systems 12 Oct 13, 2014 09:36 PM
Discussion Why are RC aircraft flight times so short compared to RC cars? Maj.Duty Batteries and Chargers 17 Mar 14, 2014 02:12 AM
Help! Quadcopter short flight time atbtomaha Multirotor Talk 8 May 23, 2013 04:07 AM
