Old Jan 22, 2014, 11:20 PM
Jim Deck is offline
Find More Posts by Jim Deck
Jim Deck's Avatar
Valparaiso, IN
Joined Apr 2005
Thrust line Advice
For those struggling to get the trust line correct when converting to a "winch in the nose", I offer this sage piece of "advice" from another forum:
"Model airplanes need right engine offset to counter-act the exhaust push from gas engines which always have the exhaust blowing out the right side. Electric motors don't have an exhaust therefore have no need for the offset."
Now you know why electric power is growing in popularity
Jim Deck is offline Find More Posts by Jim Deck
Old Jan 23, 2014, 04:10 PM
Leadchucker is offline
Find More Posts by Leadchucker
AMA7224 LSF1832
Leadchucker's Avatar
United States, NJ, North Wildwood
Joined Sep 2008
:Who don't know that?
Leadchucker is offline Find More Posts by Leadchucker
Old Jan 23, 2014, 04:13 PM
Lenny970 is online now
Find More Posts by Lenny970
Lenny970's Avatar
Greeley, Colorado, USA
Joined Feb 2000
I guess left thrust would be in order then if the glow engine were inverted!
Lenny
Lenny970 is online now Find More Posts by Lenny970
Old Jan 23, 2014, 07:27 PM
Fly Wheel is offline
Find More Posts by Fly Wheel
Ochroma Pyramidale Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
Then why do most electric planes have down and side thrust in their plans? Isn't there a prop effect that requires this?
Fly Wheel is offline Find More Posts by Fly Wheel
Old Jan 23, 2014, 07:48 PM
ScottSails is offline
Find More Posts by ScottSails
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
Yes, its due to torque from the motor from twisting the prop... Surprisingly even happens on rubber powered planes...
Scott
ScottSails is offline Find More Posts by ScottSails
Old Jan 24, 2014, 11:05 AM
Chuchuf is offline
Find More Posts by Chuchuf
Joined Aug 2009
ALL single engine/motor prop planes will have the following influencing how much left and down thrust the plane requires.
* P Factor (asymmetric propeller loading) is what has great influence on a single engine prop plane wanting to yaw to the left. RPM, Blade Size and Pitch of the blade will all influence the amount of P-Factor
* Propeller Wash causes a twisting helix pushes on the left side of the tail causing the plane to yaw left
* Propeller Torque Effect causes the plane to rotate ccw if the prop is spinning CW which induces adverse yaw to the left.
I would seriously doubt that the influence of open stack exhaust would be any where as much of an influence of the above to cause adverse yaw.
And as you all know this yaw can be overcome by right and down thrust of the motor/engine.
Terry
Chuchuf is offline Find More Posts by Chuchuf
Old Jan 24, 2014, 12:45 PM
azdiane is offline
Find More Posts by azdiane
Addicted to lazy-flying models
azdiane's Avatar
United States, AZ, Chino Valley
Joined Apr 2013
dead on
Terry is dead on about P-factor. It wouldn't matter if the prop were driven by fuel, electricity, or a very strong hamster. It's the fact that if the downthrust is proper each blade operates at a slightly higher blade angle of attack as it descends compared to when it ascends. This produces slightly more thrust on the descending blade side, causing a tendency to yaw.
If we ran a counter-clockwise motor rotation with a prop designed for that rotation, with the descending blade on the left, we would find a tendency for the model to yaw right.
Go easy, lateral thrust-line offset is easy to overdo, and in my opinion much less critical that getting the vertical alignment right to prevent unintentional looping on launch.
Diane
azdiane is offline Find More Posts by azdiane
Old Jan 24, 2014, 01:22 PM
War is Peace is offline
Find More Posts by War is Peace
Enemy of the State
War is Peace's Avatar
United States
Joined Mar 2012
I build in about 2.5 degrees down thrust and then use the radio to mix in some down elevator in proportion to the amount of throttle. It only takes a few flights to get it dialed in. I don't worry about left/right as I'm usually steering the model in a particular direction during climb anyway.
War is Peace is offline Find More Posts by War is Peace
Old Jan 24, 2014, 03:44 PM
craigrrr is offline
Find More Posts by craigrrr
craigrrr's Avatar
San Diego area
Joined Jul 2006
For SAILPLANES I think it is simpler to just mount the motor straight.
Then, mix elevator and rudder to the motor as required.
Craig
craigrrr is offline Find More Posts by craigrrr
Old Jan 24, 2014, 07:01 PM
dion9146 is offline
Find More Posts by dion9146
dion9146's Avatar
United States, KY, La Grange
Joined Feb 2006
Craig
That's what I have done on all of my e-sailplanes, then I just fly it. No mixing required.
After all, the object is to get it to a spot at altitude not fly it like a sport plane, right?
Dion
dion9146 is offline Find More Posts by dion9146
Old Jan 25, 2014, 06:30 AM
Al M is offline
Find More Posts by Al M
Wallingford, Ct
Joined Sep 2001
For sailplanes it is easy enough to make any mixing/corrections with the stick. That is what it is for.
Al M is offline Find More Posts by Al M
Old Jan 25, 2014, 06:49 AM
AMA7224 LSF1832
Joined Sep 2008
Yup, thumb/brain interface works for me.
Discussion Cord Line / Thrust line Butch777 Flying Wings 21 Sep 10, 2014 04:08 AM
Discussion 3kg Quad lacks thrust.. Need Advice flyingdogfilms Multirotor Power Systems 18 Jan 17, 2014 12:43 PM
Discussion thrust line? pathfinder The Builders Workshop 12 Dec 07, 2013 10:58 PM
Discussion Boeing 727 Thrust Line PC Pilot RC Airliners (Commercial, Cargo, Troop Carrier) 14 Dec 02, 2013 06:04 PM
Discussion Need Advice on Thrust Line Setting and now about improving the power. fooyukvoon Flying Wings 7 Jan 01, 2012 12:03 AM
