Old Dec 31, 2013, 07:20 PM
Petrie is offline
Find More Posts by Petrie
United States, AR, Lockesburg
Joined Feb 2012
LED Controller
I am using a LED strip powered by a 3S Lipo on an irrigation reel. They work great but I need some way to protect the Lipo from discharging to low of voltage. Is there some way I can connect a ESC up to it and use the LVC on the ESC? Not sure how to make the ESC run at full power to get the 12V without being connected to a radio. Maybe someone can recommend something else that can switch power off at a set voltage?
Petrie is offline Find More Posts by Petrie
Old Dec 31, 2013, 08:29 PM
Petrie is offline
Joined Feb 2012
Someone just told me to use a servo tester. That will work great.
Old Jan 02, 2014, 08:15 AM
dmccormick001 is online now
Find More Posts by dmccormick001
Dave the Rave
dmccormick001's Avatar
Joined Jun 2007
If the ESC is left connected to the servo tester, the circuit of the tester will continue to drain some current from the Li-Po, even after the LEDs quit conducting, so be aware of that. You can't leave it connected indefinitely.
dmccormick001 is online now Find More Posts by dmccormick001
Old Jan 02, 2014, 04:44 PM
Petrie is offline
Joined Feb 2012
Thanks you are correct. Someone gave me the great idea of going to Walmart and getting some of the $.99 garden solar lights and just tie rap to one of the arms on the reel. No wires, no switches, self contained and weather proof. Problem solved for $3.00.
Old Jan 03, 2014, 09:42 AM
Dave the Rave
Joined Jun 2007
K.I.S.S. is one of my core principles.
Another one is "Better is the enemy of Good". That reminder has saved me from screwing up a lot of things that were working just fine.
For Sale DJI Phantom Naza/GPS/LED/PMU/Controller & RX Lroc130 Aircraft - Electric - Multirotor (FS/W) 0 Dec 14, 2013 10:50 PM
Wanted LED Light Controller JetMang Aircraft - General - Miscellaneous (FS/W) 0 Dec 10, 2013 06:51 PM
Sold Mikrokopter PCB Extension Set - assembled and ready to control LED's, camera, etc. Mactadpole Aircraft - Electric - Multirotor (FS/W) 1 Nov 27, 2013 08:26 PM
Question How to setup T6J TX for LED Control Unit toomanydavids Multirotor Talk 1 Oct 28, 2013 06:56 PM
Discussion Controlling LEDs with a brushed ESC - This'll work... right? acetech09 DIY Electronics 2 Oct 11, 2013 08:55 AM
