Old Jun 09, 2014, 06:45 AM
carlnoki is offline
Find More Posts by carlnoki
carlnoki's Avatar
United States, VA, Woodbridge
Joined Dec 2010
I used the bolt on prop adapter.
no mods needed.
I use this one: http://www.valuehobby.com/power-syst...with-ubec.html
carlnoki is offline Find More Posts by carlnoki
Old Jun 09, 2014, 07:55 AM
ltc is online now
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
no mods needed.
Thanks.
Its nice that the motor uses the same X mount pattern. It seemed slightly larger than the stock motor, but you can't ask for better than a drop in.
ltc is online now Find More Posts by ltc
Old Jun 16, 2014, 06:51 PM
ltc is online now
ltc
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
request for a little help
Hi,
Could someone with a stock Arcus do a quick check for me?
While swapping out the 900kV motor with the HobbyKing 850kV motor, I wasn't expecting there to be washers hiding between the X mount and the plastic firewall
I "think" there were 2 washers on the top left and 2 washers on the bottom left.
Based on the gap between the spinner and the cowling, this looks to be correct.
Lots of right thrust and looks to be about zero to very slightly down thrust with the new motor installed.
(the Hobbyking 850kV is the same size, weight, bolt pattern, X mount and prop adapter as the stock 900kV)
Can someone take a quick look and verify these washer locations?
Thanks in advance.
BTW, with the Glacier 4s 1800 30C, a Xoar 12x7 (Falcon 12x7 carbon fiber props shipped today), stock ESC and the 850kV motor, the wattmeter was showing 425-440watts at about 32 amps at full throttle (ATV set to 95% on my throttle channel). Just about what eCalc had predicted and within the max rating of the motor. Don't think I'll be in full throttle for very long (seems to have more than enough power to weight )
Old Jun 23, 2014, 03:27 PM
ltc is online now
ltc
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
Nothing better than a maiden flight that puts a smile on your face.
10 mph winds, but it flew beautifully. The 850kV motor, 12x6 CF prop, Glacier 4s/1800 all worked great.
If this plane is ever scaled up in size and offered, I will be first in line to order one.
Old Jun 23, 2014, 04:58 PM
3Deranged is online now
Find More Posts by 3Deranged
Aerodynamically challenged
3Deranged's Avatar
3D World, Florida
Joined May 2005
Already called dibs-you'll have to take second or third behind me and Blake!LOL
3Deranged is online now Find More Posts by 3Deranged
Old Aug 22, 2014, 01:27 AM
peterreebok is online now
Find More Posts by peterreebok
Australia, VIC, Ferntree Gully
Joined Nov 2010
Been flying for a while, Arcus met the criteria for a (sacrificable) plane to see if pattern might excite me.
ordered monday, delivered thursday, built and maidened Friday.
I did use 4S batteries rather than 3S, and no shortage of power. flies best on 1/2 to 2/3 throttle, Nice round loops, no coupling in rolls, lands and takes off like a dream.
tracks straight and true. only four flights today just to prove it. tomorrow another few flights, this time I will use full rates. Very vice free airframe. from initial setup, just needed three clicks of down, one of left rudder. would like a longer flight time, I am getting 6 minutes.
suggestions?
peterreebok is online now Find More Posts by peterreebok
Old Aug 22, 2014, 06:07 AM
ltc is online now
ltc
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
6 minutes should be enough to complete a full sequence.
That's about what I am getting with my 4s 1800 with 12x6 prop...and that is charging to 4.1V and landing at 3.8V per cell.
Old Aug 22, 2014, 08:29 PM
HouseOf4Doors is offline
Find More Posts by HouseOf4Doors
HouseOf4Doors's Avatar
United States, CA, Richmond
Joined Dec 2007
suggestions?
Well, what's the verdict - does pattern excite you?
HouseOf4Doors is offline Find More Posts by HouseOf4Doors
Old Aug 22, 2014, 11:38 PM
Joined Nov 2010
So far, seems a better task than just flying around. hey I might even learn something about control!.
seriously, it amazes me how many people cant fly a straight and level pass down the field, do a procedure turn, or do 3 loops in the same axis.
I decided to take matters into my own hands and make myself a more controlled pilot.
may not be able to influence anyone else, but I can improve my skills instead. Already have learnt about setup, approach and maintaining position by using less and less input on the controls. certainly cant hurt.
Old Oct 02, 2014, 02:24 PM
Joined Dec 2007
so far, seems a better task than just flying around. Hey i might even learn something about control!.
Seriously, it amazes me how many people cant fly a straight and level pass down the field, do a procedure turn, or do 3 loops in the same axis.
May not be able to influence anyone else, but i can improve my skills instead. Already have learnt about setup, approach and maintaining position by using less and less input on the controls. Certainly cant hurt.
awesome!
Old May 07, 2015, 05:45 PM
Jim Taylor is offline
Find More Posts by Jim Taylor
Wexford, PA
Joined Mar 2001
Hi,
Thanks in advance.
I took the motor out today to do some repairs and wasn't expecting washers either. I ended up with two washers on the bench and don't know if I lost any or where the two go. I don't see an answer to the quoted post, so if anybody knows how many washers there should be and where they go I would appreciate the information.
Edit: I found two more washers that are stuck together. So I now have a total of 4 like ltc. Guess if no one posts I'll go with two top left and bottom left for more right thrust like he was thinking.
Jim
Jim Taylor is offline Find More Posts by Jim Taylor
New Product Hornet X4S PRO Carbon - preview marimach77 Multirotor Talk 20 May 16, 2012 12:52 PM
Wanted Ayk Radiant Pro / Viper / Shuttle murphy3428 Cars - Cars and Parts (FS/W) 0 Dec 18, 2008 05:07 PM
Wanted TRADE JR Venture 50 for Shuttle Plus or Hawk Pro JSTFISH Aircraft - Fuel - Helis (FS/W) 0 May 08, 2006 04:21 PM
