Old May 06, 2013, 06:27 PM
MightyG is offline
Find More Posts by MightyG
MightyG
MightyG's Avatar
Joined Mar 2013
Help!
Stripped Servo Gears - Need parts!
Hi All,
I have some stripped gears in some of my servo's...
So I ordered some new gears from a distributor...
But this is what I received...
The packet says HS003-2A, but notice that the final gear comes pre moulded with a shaft. It appears that there are 2 types of HS003 servos and I have both! Ones that require the final gear with a plastic shaft and ones that don't!
Happy to keep the new gears as they fit the servo's that came with my "newer" X3V, but I need gears to go with the servo's that came with my "older" X3V
From the pictures on the skyartec web site I assumed that the gears that came with the final gear with the plastic shaft are part HS003-2B and the gears without the plastic shaft are part HS003-2B
But according the distributor...
"hello, we contacted the factory just now, they said the old HS003-2A was stopped to make, the new one is same like the one you got, thank you :-)"
So does anybody know what part I do need, or how to make the new final gear fit into the "older" HS003 servo?
Cheers
Simon
MightyG is offline Find More Posts by MightyG
Sold New Futaba Replacement Servo Gear Sets & Other Parts pnman Aircraft - General - Radio Equipment (FS/W) 0 Apr 11, 2013 07:01 PM
Question Metal-geared servos for flaps needed? FlyBoy20 Beginner Training Area (Aircraft-Electric) 4 Apr 03, 2013 09:27 PM
Sold New Futaba Replacement Servo Gear Sets & Other Parts pnman Aircraft - General - Radio Equipment (FS/W) 0 Mar 28, 2013 07:38 PM
Wanted wtb stripped gear- blue bird bms 385dmax servo Pkitup Aircraft - General - Radio Equipment (FS/W) 0 Mar 21, 2013 03:47 PM
Servo horns, NIP GWS servo gear set, stripped gear Futaba 3108 servo jettvolks Non R/C Items (FS/W) 5 Jan 25, 2008 04:18 PM
