Old Mar 29, 2013, 12:24 AM
Dingo24 is offline
Find More Posts by Dingo24
Australia, WA, Marrinup
Joined Jul 2012
Spektrum DX / Motor Issue
Hi Guys,
Here is an interesting problem I can't figure out. Put together a new Dynam meteor,bound it to my Spektrum DX7 but blew the motor with an unbalanced fan. Everything went together and worked correctly until I blew the motor. Then the fun stated.
I replaced the motor and fan, put everything back together but I couldn't get the throttle to arm.. with the very bad "beep .. Beep" tone every two seconds. Tried throttle calbrating, rebinding, replacing receiver with spektrum and orange 610, all with the same problem. Tried swapping the esc with a dual sky, same problem, tried different motors, same problem. Thinking it was a transmitter problem I tried my dx6, just had the same dramas.
Then I went and ran a bench test with all new gear (servo, motor, esc, receiver) and the beeping problem continued. Went through and replaced everything against and still didn't get it to work.
I can swap receivers and rebind on my existing aircraft and everything is ok... just not anything with a new esc. I've tried reversing throttle etc and resetting tx, still the same problem.
Any ideas?
Dingo
Dingo24 is offline Find More Posts by Dingo24
Old Mar 29, 2013, 03:26 AM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Presumably your other servos are working when the ESC is not arming?
Usually that beep tells you that the ESC has power, but is getting no valid signal. So, have you tried a servo in the throttle channel to see if its putting out a proper signal?
abenn is online now Find More Posts by abenn
Question Spektrum DX-8 SD Card Usage PapaMichael6464 Radios 5 May 09, 2014 07:03 PM
Discussion Spektrum DX 18 setup for 4-servo wings JoHowell Thermal 3 Jan 24, 2013 07:16 PM
Sold Spektrum DX3.0 DX 3.0 digital computer radio xtremetoyz Cars - Cars and Parts (FS/W) 4 Jan 12, 2013 02:33 PM
Sold Spektrum DX-7 transmitter yankphan Aircraft - General - Radio Equipment (FS/W) 2 Jan 08, 2013 06:33 AM
Sold SPEKTRUM DX 7SE -- rare Special Edition endeavor Aircraft - General - Radio Equipment (FS/W) 3 Jan 03, 2013 08:22 PM
