Old Feb 08, 2013, 07:36 AM
rcnutt is offline
Find More Posts by rcnutt
Centerville, In. USA
Joined Jul 2001
soldering servo wires to rx pins?
I bought some very light stuff from Hobby King to make a flight pack. I have a Berg like receiver making it the heaviest component of the flight pack. The servos have the wrong ends on them so I was thinking o soldering the servo wires directly to the receiver pins to lose the weight of the connectors. . Is this OK to do? Will the heat from the soldering damage the Rx? Any tips? RCNutt
rcnutt is offline Find More Posts by rcnutt
Old Feb 08, 2013, 08:49 AM
ror is offline
ror
Find More Posts by ror
ror
France, Languedoc-Roussillon, Thuir
Joined Aug 2009
No pb ! I did it there is a lot of years on a Rx and it flew very well .
ror is offline Find More Posts by ror
Old Feb 08, 2013, 09:39 AM
rcnutt is offline
Joined Jul 2001
Thanx, I give it a go! RCNutt
Old Feb 11, 2013, 02:47 AM
ror is offline
ror
ror
Joined Aug 2009
maybe add a little shrink tube on each pins/wires
Old Feb 11, 2013, 03:12 AM
methuso is offline
Find More Posts by methuso
A.K.A sir Crashalot
methuso's Avatar
Ístersund, SWEDEN
Joined Sep 2005
While Your at it. Why not desolder the pins from the RX too and solder the wires directly to the pcb? not much harder but saves some weight
methuso is offline Find More Posts by methuso
Old Feb 11, 2013, 06:25 AM
rcnutt is offline
Joined Jul 2001
Looking for a tiny rx
I soldered the servo wires directly to the pins and everything is working. What I would really like is a micro rx that doesn't cost an arm and a leg. I have a standard 72 mhz Tx. My rx is big and clunky next to my other airborne flight pack parts. Any suggestions? RCNutt
Old Feb 11, 2013, 12:43 PM
davidTs is offline
Find More Posts by davidTs
Joined Nov 2012
I do not suggest soldering servo wires to rx, unless ~0.5 gr gain is important for you.
davidTs is offline Find More Posts by davidTs
Old Feb 11, 2013, 12:59 PM
rcnutt is offline
Joined Jul 2001
The reason I soldered onto the pins was that the servos came with the wrong ends on them. So I had to do the soldering anyhow and come up with some Futaba servo ends. It was easier and it is a tiny bit lighter as a bonus. RCNutt
Old Feb 11, 2013, 01:08 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Certainly Do able if somewhat Hill Billy :-)
It can get a bit fiddly in there when soldering and the subsequent adequate removal of solder on those Rx pins may preclude using connecters again. Ain't no free lunch.. ever :-)
But remember that The Berg uses Chips and that Means NO Soldering guns only Pencils
Dunno that one can? find a 72mhz Rx lighter than a Castle Berg. Mine measure 3.7 gms
Even newest 2.4hz chip Rx's are in the 3 gm range.
What I've Finally ! realized is that Models have a rather Nasty trend to always Smaller.
Invariably a step or 2 beyond whatever Avionics one currently owns.. regardless of just how tiny it was.. last week..
Pick a size that your gear is small enough for (likely a 3" Bigger wingspan, than the current Hot Topic model size).. And Relax.
Bare is offline Find More Posts by Bare
Old Feb 11, 2013, 02:07 PM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
I have several of the ZX Technology 4 channels Rx(72 Mhz)and they work fine, they come with jst servo connectors (S,Gnd and V+ order,same as Plantraco servo Rx). BP Hobbies still has the 6 channels version:
http://www.bphobbies.com/view.asp?id...4&pid=E1704723
As well as a few other places(ZX Tech. no longer exist!)
http://www.bidproduct.com/part/Produ...YSTAL_110.html
http://www.rcgroups.com/forums/showthread.php?t=1014621
coriolan is online now Find More Posts by coriolan
Old Feb 13, 2013, 12:29 AM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
Consider converting to 2.4 DSM?
LemonRx has a 1.4g, 6 ch (no pin) Rx for $6.
Full LemonRx line.
LemonRx thread.
KC is offline Find More Posts by KC
Question Soldering Brass Tube / music wire mag1 The Builders Workshop 4 Feb 12, 2013 11:24 AM
Question Can RX antenna be soldered to std. Music Wire? Phiber Optik Hand Launch 10 Mar 18, 2007 11:27 PM
Servo wire for JR and JR Male pins RC Accessory Aircraft - Fuel - Airplanes (FS/W) 0 Jan 15, 2004 05:44 AM
In-flight radio glitching. Caused by soldering extra wire to Phx-45 rx connector? 717 Castle Creations 1 Oct 20, 2003 10:24 AM
