Old Nov 18, 2012, 12:51 AM
R Zielinski is offline
Find More Posts by R Zielinski
R Zielinski's Avatar
USA, NH, Madbury
Joined Dec 2007
Help!
How hard is this to fix?
I nosed this motor in, pushing it back against mounting screws. A screw head crushed the wires. I've never worked on motors, so I don't know how to get the stator off the thrust tube. It looks like there's enough wire in there to graft on new wires, but I wonder how hard it is to solder that coated wire. I also can't get the 2 stacked front bearings out. Looking for advice on fixing vs. replacing with a $50 no name motor. It is a nice Reaper GR 60, so hate to use it as a paperweight. If anyone is interested in fixing these wires and getting the bearings out for a fee, let me know.
R Zielinski is offline Find More Posts by R Zielinski
Old Nov 18, 2012, 01:14 AM
C₄H₁₀ is offline
Find More Posts by C₄H₁₀
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
Ouch.
That's a pretty tough repair unless you want to completely rewind it. The motor leads in this case are just the ends of the windings extended out, so to solder them you'd have to strip the enamel off all the individual strands. I use fire and sandpaper... That in itself is a tricky proposal with so little wire to work with.
Getting the stator off the bearing tube without damaging the windings any further would be a challenge. Normally, I like to bolt the backplate to some sort of mount, wrap the stator in a few layers of protective cloth or leather, and then twist and pull it off with a large pair of pliers. Heat is usually required to soften adhesives, but I've had a few that didn't need any. That heat will hammer the winding insulation, though, so ya gotta be careful. Maybe pop the bearings out if possible and stick a soldering iron up the bearing tube for a few seconds...
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Nov 18, 2012, 07:28 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
It it the motor in the image? The GR-60XL?
Here is a thread on getting motors apart, that and some photos to see if it looks like it is worth re-winding would be a good start:
http://www.rcgroups.com/forums/showthread.php?t=1079423
Jack
jackerbes is offline Find More Posts by jackerbes
Old Nov 18, 2012, 09:53 AM
USA, NH, Madbury
Joined Dec 2007
Argh. I was afraid of that. I'm not really up to attempting a rewind on this. It looks like it has 12 miles of wire in it, packed VERY tightly. I bought this used and was told it was the original GR 60 with Kv about 850. However, there were apparently some XL's sold that had no identification and used the same label. It certainly looks like the thinnest wire possible, so I can't imagine what the XL windings look like. Wouldn't it have to be even thinner to get the Kv down? Maybe this IS the XL version. I never put a tach on it. Looks like a moot point anyway, as it will make the same aquarium feature either way.
Old Nov 18, 2012, 10:04 AM
C₄H₁₀ is offline
C₄H₁₀'s Avatar
Joined Aug 2009
My guess is that it's wound with many parallel strands of very thin wire, which is a common practice that allows manufacturers to keep just one wire gauge on hand while using it for many different motor sizes and winding schemes. To lower the Kv of a motor, they just run less strands in parallel to get more turns in there. There are probably only a few actual turns on that stator.
If you rewound it with one strand of much thicker wire (or maybe two or three in parallel), you could almost certainly increase copper fill, efficiency, and performance without a really huge amount of effort.
Old Nov 18, 2012, 10:15 AM
Jack
USA, ME, Ellsworth
Joined May 2008
What C₄H₁₀ said!
The total surface area in all of the parallel strands decides the current capacity. So ten parallel small strands can be as good as one large strand. The number of turns and termination method use, and only those, decides what the Kv will be for the set of components in the motor. The surface in the wire decides the current capacity.
It is impractical to use a single large strand and wind a motor that large. Also it is easier for cheap Chinese motor makers to have to only stock one size of wire (0.25mm dia. typically) and just vary the strand count to wind different motors. Other wise they would have to stock a wide range of wire sizes.
Look at the image, that is an 18 turn motor with a factory wind and the same motor rewound to about the same turn count with a single strand. It is also a different wind but that is incidental to my needs as far as best matching the motor to a prop and battery voltage.
Your bigger motor may be a re-wind candidate, I think using two or three larger strands would be the approach I would take.
Jack
Old Nov 18, 2012, 04:49 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
If the wires aren't shorting each other or to the case, I'd just cover the whole area with shoo-goo.
Maybe a coat of polyurethane varnish over the exposed wire and then a coat of shoo-goo.
hoppy is offline Find More Posts by hoppy
Old Nov 18, 2012, 04:51 PM
C₄H₁₀ is offline
C₄H₁₀'s Avatar
Joined Aug 2009
Hoppy, some of the strands themselves are severed. The motor might still run without them connected, but efficiency will take a big hit.
Old Nov 18, 2012, 05:26 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
If those aren't motor winding wires that are cut, I don't think it would be a problem. If they are motor windings, I agree with you.
Old Nov 18, 2012, 05:40 PM
Jack
USA, ME, Ellsworth
Joined May 2008
The damaged wires are the windings, you can see that in the photos.
They brought the bundles of the parallel strand winding wires out and cased them in heat shrink tubing.
That is very typical work.
The motor needs to come apart, and have the bearings and windings checked. When you fire up a motor that is damaged like that you are playing "you bet your ESC" if you have not checked things out. And burned up ESCs are a lot harder to fix than motors...
Jack
Question how to fix this? cf tube tail boom getmeoutofiraq Hand Launch 9 Jun 23, 2012 02:22 AM
Question How should i fix this broken motor mount? wopachop Electric Plane Talk 22 Apr 13, 2012 11:01 AM
Discussion How can I fix this motor? Does it need fixing? swbluto Electric Motor Design and Construction 12 Nov 30, 2009 04:58 PM
Discussion How can I fix this motor? Does it need fixing? swbluto Power Systems 3 Nov 22, 2009 02:53 PM
Discussion glass fuz T-tail gone all wobbley after a hard landing, how to fix?? Phillybaby Slope 9 Mar 24, 2008 09:42 PM
