Old Jul 15, 2010, 04:48 PM
nzjon is offline
Find More Posts by nzjon
Whangerei New Zealand
Joined Aug 2009
Question
Micro-trnics
The Spectrum AR6400 ultra microlite reciever is a fantistic development in ultra small set up's-the instructions indicate that it is both brushed and brushless compatable-- Horizon Hobby tech people tell me they havent developed the brushless yet and advised me to find out what the boys are using in RC Groups So what are you using in a brushless set up?
nzjon is offline Find More Posts by nzjon
Old Jul 16, 2010, 06:04 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
A few people have used a 1S brushless setup, but the results are not fantastic since you get pretty much the same power as the brushed motor. Sure enough, your motor will last forever, but it's not the greatest.
If you want to go brushless, then a 2S system really shine! Keep in mind that you have to operate the AR6400 at 4.2V though, so ideally, you want to use a small ESC that has a 5V BEC. You can then simply use a 1N4004 diode between the ouput of the BEC and the AR6400 which will lower the voltage close enough for your AR6400.
So from there, it's only a question of picking a decent ESC (3 to 5 amps), a decent brushless motor, and a suitable propeller.
Read the instruction manual for the AR6400 to see how to switch the connector to external ESC and have fun. In 2S, you can take pretty much any ultra-micro and make it go warp speed.
Good luck
RealGambler is offline Find More Posts by RealGambler
Old Jul 17, 2010, 01:19 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
i have used a AP-05 motor on 2s in the UM SU-26 and it was a rocket with a 4.5x4 gws prop
i did the above diode mod to keep the rx from croaking.
here is the motor i used: link
derk is offline Find More Posts by derk
Old Jul 17, 2010, 01:58 PM
Denile is offline
Find More Posts by Denile
M16 CIII/AR15/FN 2000 and PS90
Denile's Avatar
United States, AR, Waldron
Joined Jan 2005
Have a look in the micro and indoor forum, there a lot of info there about setups and planes the 6400 works good with.
Denile is offline Find More Posts by Denile
For Sale micro esc bs-8d low voltage bec 3.3for micro receivers rudyhal Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 May 12, 2010 07:47 AM
Discussion Micro Kit to transfer my Micro Cub Motor and Electronic into? 5 Volt Robert Foamies (Kits) 1 Apr 11, 2010 05:22 PM
Sold Berg Micro Stamp 4  with micro antenna Maarksc Aircraft - General - Radio Equipment (FS/W) 1 Mar 29, 2010 03:10 PM
For Sale Micro lights for your micro heli! Butters Aircraft - Electric - Helis (FS/W) 5 Mar 02, 2010 11:52 AM
Sold Micro Light for your Micro Heli Butters Aircraft - Electric - Helis (FS/W) 0 Feb 27, 2010 06:15 PM
