Old Nov 29, 2004, 07:44 AM
Willow Grove, Pa.
Joined Jun 2004
Tigermoth 400 questions?
Hey Guys,
I have been planning on building a GWS TM 400 for a while now, and I really want to do this right. What I am looking for are the best components so that I can start getting everything together. What I need are the following:
1. I seem to be having difficulty finding a source for the kit in the WHITE unpainted version.
2. Choice of brushless motor / ESC. Recomendations ? ( I was very happy with a Mega 16/15/4 in a 48" Unicorn) or should I stay with the S 400? I'm not trying to tear the wings off the plane, I just want it to fly well, and be aerobatic.
3. Choice of battery packs? I am looking for flight duration, and adequate power. I am also looking to get into Lipos, but maybe not until spring, depending on whether it just makes sense to go the Lipo route from the get-go.
4. Alternative prop choices other than the 10 x 6
5. Looking for info on building mods, so that I don't have to retrofit later, I.E. strengthening weak points, improvements, etc. There is a lot on the smaller version but not too much on the larger plane. I also have not seen anything as to landing gear reinforcement issues. I know this was a weak point with the smaller version.
This is my winter project, and the plan is to build it slow, and have the best possible result. Your help is much appreciated.
WThesing is offline Find More Posts by WThesing
Old Nov 29, 2004, 08:25 AM
Straight up is all I ask
Fairfield Ct USA
Joined Apr 2002
I glassed my tm400 and most recently installed my mega 16 15 3 with a top creations gearbox ,only 1/2 oz heavierthan eflight 400. Your 4 turn and 2.5 gearbox with 12x6 propwould be a great combo . I also cut ailerons in the top wing for a better roll rate,you can always do that later .
jmolwitz is offline Find More Posts by jmolwitz
Old Nov 29, 2004, 07:05 PM
Willow Grove, Pa.
Joined Jun 2004
I appreciate the tip on the motor/prop. The Mega that I have is staying in the Unicorn. Should I consider getting another, or is there a better choice?
Old Nov 29, 2004, 09:33 PM
Fairfield Ct USA
Joined Apr 2002
I like the 3 turn the best for flexability . Upto 320 watts on my formosa only 240 watts for my moth . I fly sp300 sp400 & sp600 planes with these motors 350 whatts is possible with 4s packs . Also this motor is only 1/2oz more than my eflight pork400 brushless.
Old Nov 30, 2004, 03:22 PM
Willow Grove, Pa.
Joined Jun 2004
Should I consider the Phoenix 35 ESC or swap out the Phoenix 25 from the Corn? I could then use the 35 in the wing.
Old Nov 30, 2004, 06:36 PM
Registered Disabuser
Wertygrog's Avatar
Norfolk, Massachussetts
Joined Jul 2003
I'd swap the -25 or get a new -25, as you prob won't be needing more than that!
Wertygrog is offline Find More Posts by Wertygrog
Old Nov 30, 2004, 07:54 PM
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
W.....
PM Vammy on the GWS forum or else send him an E mail at Sales@eflyerparts.com
He is one of the best GWS suppliers with great prices and super service. He might be able to help you get your kit. He alsoflys what he sells and can help with best setup. he also carries motors and batts...
Try him ...I think you'll be happy..I buy almost everything from him...
mjdee14 is offline Find More Posts by mjdee14
Old Nov 30, 2004, 11:51 PM
Vampowered!
Vamooska's Avatar
Crestview Florida
Joined Dec 2003
Hi,
I will get the TM 400 in whatever setup you want. I have the Yellow ones in stock with the 400 motor. They fly very well stock. I can also get the white unpainted version for you too. I will be placing a follow up order with GWS soon and and would be more than happy to add anything I dont have in stock to the order!
Peace and Happy Holidays
Vammy
Vamooska is offline Find More Posts by Vamooska
Old Dec 02, 2004, 06:43 AM
Willow Grove, Pa.
Joined Jun 2004
Appreciate the feedback. I will be placing an order soon, but I have to hold off for now, as I don't want to rain on my wife's parade with whatever holiday shopping she is currently doing. She knows that I have been planning this since late summer.
Bill
Old Mar 15, 2005, 09:34 PM
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
I just finished the TM 400... Everything per kit... motor, prop, battery..8x800 Nimh.
All up weight 22 oz.
Flies well, much better than I expected.
It does need (apparently) a lot of aileron differential.. the nose pulls to the outside in an aileron turn..
And drops to the inside with a rudder turn..
Looks good in the air...
Sparky Paul is offline Find More Posts by Sparky Paul
Old Mar 16, 2005, 01:27 AM
e-flight in 24½th Century
Waldo Pepper's Avatar
Cypress, TX
Joined Jul 2004
Any problems with LG attachment?
walt
Waldo Pepper is offline Find More Posts by Waldo Pepper
Old Mar 16, 2005, 04:49 AM
Patrick Plawner's Avatar
United States, CA, Burlingame
Joined Sep 2001
Very nice pictures of the moth!!!
I will have to get one too, someday, after all the good things written on it.
Patrick Plawner is offline Find More Posts by Patrick Plawner
Old Mar 16, 2005, 12:00 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
I expect the gear may be a problem, but so far it's been good. I changed the ailerons to differential last night.. maybe fly today, weather depending.
It does handle a mild wind nicely.
Old Mar 16, 2005, 12:39 PM
Cypress, TX
Joined Jul 2004
I know when I was flying my nitro bipes that I had to use rudder and alierons to get smooth turns. FYI
walt
Old Mar 16, 2005, 07:09 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
The differential I put in last night improves tracking in rolls, the nose doesn't go out as far.
But the roll rate has noticeably decreased.
I cut up a servo wheel, as there isn't a wheel supplied for the Cirrus 09 I'm using, and screwed that to the existing straight arms as shown..
There's about a 50% differential now.
On the full-scale TM, it's rigged to almost no down aileron at all..
Discussion Tigermoth 400 Questions and comments jetboy11914 Parkflyers 10 Jan 09, 2007 08:33 AM
tigermoth ESC questions Smokecover Parkflyers 3 Apr 27, 2002 02:12 PM
Rocket 4.8 V 400 questions Ryan Nau Power Systems 11 Jul 30, 2001 12:14 PM
Ace Simple 400 questions slowflyer Sport Planes 7 Jun 04, 2001 10:16 PM
Skimmer 400 questions luv2fly Electric Sailplanes 1 May 11, 2001 12:05 AM
