Old Dec 09, 2013, 07:37 PM
Racing Enthusiast AMA 3557
JetMech2002's Avatar
United States, MO, Sedalia
Joined Sep 2011
Prop adapter solutions for 12mm motors?
What are you guys using for the short shaft 12mm motors?
JetMech2002 is offline Find More Posts by JetMech2002
Old Dec 09, 2013, 10:09 PM
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Most 12mm motors(GWS,Feigao,Medusa)have a 1.5mm shaft and uses a 3" prop which is just press fitted on the shaft. GWS used to have an adapter GWADP001 with a screwed on prop:
http://www.gwsus.com/english/product...ve%20shaft.htm
BP Hobby might have them:
http://www.bphobbies.com/view.asp?id=H3334949
coriolan is online now Find More Posts by coriolan
Old Dec 19, 2013, 11:00 PM
Southern MN USA
meltor's Avatar
Joined Jun 2012
I have used a piece of straw from a can of carb cleaner with a piece of wire case slid over the straw and pressed into the hub of the gws prop. the carb cleaner straw (red straw from walmart carb cleaner) will thread perfectly to the prop shaft of the parkzone p-51 ect.
I have used this method with the gws 5043 props and had great results.
meltor is offline Find More Posts by meltor
Old Dec 20, 2013, 01:54 AM
Gary
gklein's Avatar
USA, CT, Sandy Hook
Joined Dec 2009
Wire case?
gklein is offline Find More Posts by gklein
Old Dec 20, 2013, 07:45 AM
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
I like the ones Bob Selman sells.
http://www.bsdmicrorc.com/index.php?productID=665
Petefoss is online now Find More Posts by Petefoss
Old Dec 20, 2013, 09:33 AM
Belgium
Joined May 2012
http://www.microflight.com/Online-Ca...dapter-Set-4mm
for props with 4 mm bore (GWS 5" props)
drill the holes depending on the shaft diameter
HansL is offline Find More Posts by HansL
Old Dec 20, 2013, 01:33 PM
Southern MN USA
meltor's Avatar
Joined Jun 2012
Originally Posted by gklein View Post
Wire case?
yes the the covering on light electrical wire.just find the right diameter to fit the hub of the prop you are using and strip off a short piece to fit. then press the piece of plastic straw into the hub with the vinyl wire casing. if you have a bits of wire around then you should be able to find a piece that fits the hub properly.
it works, it costs you nothing.
Old Dec 20, 2013, 10:30 PM
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
The "covering" on wire? The "casing" ? It's called "insulation".
Can everyone say INSULATION ?
356Jim is offline Find More Posts by 356Jim
Old Dec 20, 2013, 10:41 PM
Southern MN USA
meltor's Avatar
Joined Jun 2012
wow.....just wow.....
Old Dec 20, 2013, 11:16 PM
Mack
Peter Mack's Avatar
Australia, VIC, Mentone
Joined Jun 2004
Simple prop adaptors can be made from credit card plastic, 1/32" ply or even pliable iron or copper wire coiled around the shaft and the ends curled to form hooks for suitably small rubber bands. Such adaptors can be fixed to the shaft with epoxy or cyano. I have had much more trouble with commercial metal prop savers with their infernal Allen key screws than with any DIY ones. Plastic ones could be better though.
Peter Mack is offline Find More Posts by Peter Mack
Discussion Prop Adapter for 28-series Brushless Motor tk240381 Electric Plane Talk 5 Nov 26, 2013 11:40 PM
Sold 4+ RCX 2822 1450KV motors with prop adapters New In Package with spare prop adapters NHmoose Aircraft - Electric - Multirotor (FS/W) 7 Oct 26, 2013 10:48 PM
Discussion Cant Find Replament 6MM Prop Adapter for Foxtech Motors akfreak Power Systems 0 Oct 10, 2013 02:17 PM
Help! Prop adapter for multistar motor NUTSgoWEEE Multirotor Power Systems 7 Sep 20, 2013 11:07 PM
Wanted 12mm bolt on prop adapter for AXI 53xx bigbobed Aircraft - Electric - Power Systems (FS/W) 0 Aug 07, 2008 04:33 PM
