Old Mar 29, 2013, 05:43 PM
United States, MN, St Paul
Joined Jan 2013
Wing Ribs with only sheeting for TE???
I'm laying out the parts of my 1st build a RCM 1/2a Basic Trainer, and am noticing some differences between the kit I ordered and the plans I found on Outerzone http://www.outerzone.co.uk/plan_details.asp?ID=3030
The one that has me most concerned at the moment is wing ribs. The plans show the outer ribs (W2) with a blunt aft to accept a trailing edge wedge. The kit I received has the same ribs tapered to a point with a notch in the top and bottom for a 1/16th inch sheet skin(?).
The plans and article I have make no mention of the change and I'm not quite sure how to proceed. Should I just sheet the trailing edge with 1/16" balsa (or Plywood)? Or is there something that I'm missing here?
Atomikbohm is offline Find More Posts by Atomikbohm
Old Mar 29, 2013, 05:51 PM
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
1/16 sheet top and bottom is fine for the TE, it is a very common method of making them.
They probably changed it because they did not want to provide the special trailing edge stock.
You should pre-taper the back end where the two sheets meet.
Are you doing it electric, or glow?
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Mar 29, 2013, 07:32 PM
United States, KY, Taylorsville
Joined Mar 2010
Sheeting the TE would be lighter but slightly more difficult. You can always cut the ends of the ribs to match pre-made TE stock.
ARUP is offline Find More Posts by ARUP
Old Mar 29, 2013, 07:45 PM
Joined Jan 2013
Pat MacKenzie
Thanks for the response Pat,
What do you mean by pre-taper? I understand that you are talking about where the two sheets meet but I'm not sure how to put them together. Any suggestions are more than welcome. Should I use Balsa or ply?
I'm going to try to run it with a cox 049 reed w/ throttle (not sure which version yet). and if that doesn't get it off the ground I'll figure it out at that point .
Old Mar 29, 2013, 07:58 PM
pmackenzie's Avatar
Joined Dec 2002
Definitely use balsa, plywood will be too heavy.
Taper was perhaps the wrong word, bevel would have been better.
Normally the ribs are a bit shorter than the chord. If you simply glue the ribs to the bottom sheet then try to glue on the top sheet it will not sit properly. By putting a small bevel in the back behind the ends of the ribs it can sit much better when you glue on the top piece.
There is a picture of a bevelled trailing edge here:
http://www.skybench.com/wf-xf_buildi...tructions.html
Second picture.
Old Mar 29, 2013, 09:55 PM
Jim C Patrick
jcpatrick's Avatar
Shenandoah County
If the sheeting is very thin, like 1/64" veneer, then beveling isn't needed. But if you have 1/16" or 3/32" sheeting you want to bevel one of the sheets to fit onto the other so you don't end up with a 1/8" thick (or thicker) trailing edge.
You still need to have some thickness on an all-balsa TE or it will break and be ragged. Some people taper the TE to a sharp edge, then run some thin CA glue on it to harden it up. Maybe this photo makes it clearer
jcpatrick is offline Find More Posts by jcpatrick
Old Mar 29, 2013, 10:04 PM
pmackenzie's Avatar
Joined Dec 2002
FWIW, I prefer to bevel both sheets, so the glue seam ends up splitting the trailling edge. Easier to sand for covering.
Old Mar 30, 2013, 12:23 AM
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Pat's method shown in the last post is ideal. But it requires a shade more skill than the other option.
My own choice, because I tend towards skillful laziness, is to lay up the wing on the building board with the trailing edge right at the edge. Then once the lower parts and ribs are in place I can sand the bevel into the lower TE piece so the angle matches the ribs. Only then would I glue the upper TE sheet piece into place.
This is sort of like what Pat showed in his first post but I find it easier to match the angle of the ribs than to pre-shape the upper portion's bevel out in the open.
BMatthews is offline Find More Posts by BMatthews
Discussion How do you align a tapered ribs on a Polyhedral wing? Atomikbohm Beginner Training Area (Fuel) 5 Mar 16, 2013 12:04 PM
Discussion Bagged wing w/ spar, d-tube, and "sheet ribs"? DKNguyen Composites Fabrication 3 Mar 10, 2011 03:05 PM
Discussion Ribbed, sheeted wing? Mr._Mulligan Hand Launch 12 Feb 24, 2008 09:10 AM
Help! 60" Bolt on wing,Root rib arrangement on a bagged wing? avago Slope 4 Mar 29, 2007 07:09 PM
Help! How to sheet ribbed wings with balsa volkksjager162 Electric Warbirds 4 Aug 09, 2006 02:04 PM
